Old 08-28-2008, 10:23 AM   #681 (permalink)
www.projectcosmos.net
Tovette's Avatar
Sensei
Realname: Nate
Send a message via AIM to Tovette Send a message via MSN to Tovette Send a message via Yahoo to Tovette
Okay new update!
I've tweaked his palette a lot and added some more color to help with the 'mass' of the head and make it a bit more solid. I also started playing with the cloak, adding folds and whatnot. He's almost done I think; just a tad more stuff to do and I'll call him done.
Tovette is offline
Old 08-28-2008, 03:00 PM   #682 (permalink)
Project Lead on SFM Film
Freak's Avatar
Realname: Dean
You done a great Job Nate
“Well, I guess wiping out 2 billion people sort of qualifies as a dick move. - Guerrilla
TH&B Project: Fighter 2 | Ships of the Naraka Empire | Ships of the Commonwealth of Solaris
Freak is offline
Old 08-28-2008, 03:36 PM   #683 (permalink)
Still Alive
backstept's Avatar
Moderator
Realname: Andy
man that looks awesome
what type of brushes do you use? would I be able to get a similar result with the default hard round brushes set to a very low opacity?
what do your layers look like?
| [_]|||||||[_] | backstept.blogspot.com
backstept is offline
Old 08-28-2008, 03:53 PM   #684 (permalink)
Ice-Dragon's Avatar
Realname: Rob
Outstanding work as always Nate
Ice-Dragon is online now
Old 08-28-2008, 11:41 PM   #685 (permalink)
Tovette's Avatar
Sensei
Realname: Nate
I mostly use a hard round brush, a feathered round brush and a textured brush. I do paint with my brushes set to about 50% opacity and with pressure falloff turned on so the less pressure I apply to the wacom table the more transparent the brush stroke becomes. Also, I use the smudge tool- alot. It's a bit of an under used tool in my opinion but with textured brushes you can get great mixes and interesting gradients with it.
As for layers, I usually start with a black drawing on a grey background. I use grey because it is a neutral color and it will compliment whatever color palette I use- black and white backgrounds will not. In fact straight black or white backgrounds can actually bias your color palette.
Anywho, after I get a sketch I like and go next to a grayscale rendering of the subject in a seperate layer under the line art layer. I never paint directly on the default background later in Photoshop.
Once I get a grayscale rendering the way I want- and its level of polish can vary greatly- I then flatten down the line art and the greyscale and then set the layer properties to hardlight as multiply just darkens everything too much and doesn't allow for color play.
I then make a new layer below the greyscale one and with a feathered brush, I start losely throwing down flat colors with a textured or hard round brush to get the base idea of what the local color of the surface will be. After that I then grab a complimentary color in the same temperature range and select a feathered brush at 50% with color dodge on. I also turn off air brushing. These colors will basically be a simple set up for where the primary light in the scene will be coming from and to lay down a blue print as to how I'm going to render out the forms of the subject. I usually paint with at least 3 lights in a scene, just like in 3D- a fill light, a bounce light, and a primary light. The primary light and bounce light are usually opposing colors that compliment eachother like blue and red, for example.
After I get that down I then start to render out the forms losely on the same layer under the greyscale but with color dodge off now, as I just sample the colors that I've laid out. Once I get a rough idea of what I painting down, I then make a new layer above the greyscale layer and start painting on top of everything. Eventually I'll merge the three layers together to keep things simple and continue to paint.
A simple rule to remember with digital painting is that if you use a soft brush too much you'll get a mushy painting and if you use a hard brush you'll get a faceted, hard rendering. You have to balance out the two.
Hope that helps.
Tovette is offline
Old 08-29-2008, 01:05 AM   #686 (permalink)
bbzwbbzw's Avatar
Realname: Zach
Thanks for sharing your work flow Nate, I for one can't wait to give it a go!
I'm bbzwbbzw, and I approved this message.
bbzwbbzw is offline
Old 08-29-2008, 06:51 AM   #687 (permalink)
Tovette's Avatar
Sensei
Realname: Nate
All done!!
There are still some races left on the galaxy map that I gotta fix up but I think I'll take some time this weekend to start on another Belkuri military uniform.
Tovette is offline
Old 08-29-2008, 07:02 AM   #688 (permalink)
somacruz145's Avatar
Realname: Adam
Now that looks bada** Are you going to do the rest of him ?
Fitter, Happier And More Productive ...
somacruz145 is online now
Old 08-29-2008, 07:15 AM   #689 (permalink)
Freak's Avatar
Realname: Dean
Very Nice Nate, you done a bang up job with this one!
Freak is offline
Old 08-29-2008, 07:28 AM   #690 (permalink)
Tovette's Avatar
Sensei
Realname: Nate
yes eventually there will be full body renders of the aliens.
Tovette is offline
