| | #31 (permalink) |
| SFM Guru | In the top menu bar, go to Image>Attributes and change the Width attribute to whatever you want it to be. |
| | #32 (permalink) |
| SFM Guru Join Date: Feb 2007 Location: UK
| got it cheers. edit: how do you manage to get attachments that big, mine always seem to go small if i upload it from an URL but when i upload one from my pc it times out. |
| | #33 (permalink) |
| SFM Guru | I finally figured out the secret to getting the flight pod paneling right. When examining the Pegasus ortho, I found that the paneling was actually mirrored along the y-axis. Thus, because it looked bad originally, I have done the same to the Zeus. |
| | #35 (permalink) |
| SFM Guru | I've made some significant updates. I had to change up the flight pod a lot because of arrangement issues. Plus, I've started on the top view. |
| | #37 (permalink) |
| SFM Guru | There have been bigger ones drawn, although they're mostly cut-and-pastes. Mine, while based upon other images, is totally original, except for the smaller guns and the flight pod arms. |
| | #39 (permalink) |
| great work dude. she looks amazing. a little suggestion would be to class it as a warstar, due to the sheer size of it, it is 1/3 bigger than Pegasus and she is a large battlestar compared to ones i have seen. just my 2 cents. but keep up the great work. |
