| SFM Guru Realname: Malcolm Join Date: May 2006 Location: Singapore Age: 25
Downloads: 3 Uploads: 0 | BS Zodiac/ Odysseus Changed this topic for the BS Zodiac. Will repost the basestar when it restarts again. New pics up on later pages. |
| Check out the latest updates at: http://gkdesigns.blogspot.com/ Last edited by Galen; 06-22-2008 at 11:52 AM. Reason: New ship done! | |
| SFM Guru Realname: Adam Kopala Join Date: Dec 2007 Location: Poland Age: 19
Downloads: 0 Uploads: 0 | I've never been into Galactica (probably because it was never aired in this part of the world ...) but I like the designs from the series so I will keep an eye on this one Are you going to do a relistic or a more cartoony version of the base ? |
| Fitter, Happier And More Productive ... | |
Downloads: 3 Uploads: 0 | I plan to make this as realistic as possible. I changed the central core by widening and shortening it. Did a basic dorsal layout. Not too satisfied with the shape. Any ideas on improving it? |
| Check out the latest updates at: http://gkdesigns.blogspot.com/ | |
| SFM Guru Realname: Andrew Join Date: May 2006 Location: Colorado
Downloads: 1 Uploads: 0 | Shorten the core even more, thin out the upper arms of the "Y", and reduce the angle of the upper arms of the "Y". This might help (baseship schematic): http://www.shipschematics.net/bsg/im..._cylon_mk2.jpg |
| SFM Nugget Join Date: Jun 2006 Age: 23
Downloads: 0 Uploads: 0 | I'm not very good at drawing anything, but I thought of this when a super-basestar came to mind....the four main arms mimic each other top and bottom...but the top and bottom extra arms are opposite each other. |
Downloads: 3 Uploads: 0 | Thanks for the tip ENdeavour. BUt i was hoping to make this Baseship a little different and larger than the Normal basestars. Thus the thicker arms. |
| | #9 (permalink) |
Downloads: 3 Uploads: 0 | Just a quick update. Added small details to the Baseship, also added a companion for her:The Battlestar Zodiac. |
