Old 05-08-2008, 02:57 PM   #1 (permalink)
Realname: Zach
Max 3ds max Subselection opacity
Here you can see..
I have a transparent material. When I select a poly it turns them red, 100% opacity.
And then you can see I can't see my image planes behind it then.
This is extremely annoying.. It makes it impossible to trace over and stuff.
I want my sub selection to be translucent..
The only thing that works is checking "wire" on the material editor. This makes edges red.. but i HATE looking at my model in wireframe.
-I'm using max2009.
-Lower opacity on material obviously doesn't work. Subselection is still 100% opaque.
-alt+x / object properties > see-through doesn't work. Subselection is still 100% opaque.
-I've spent many hours the past two days trying to google it.. I've asked professional artists working on games using 3dsmax and they don't know either. :/
-Customize UI>Colors>Geometry>Subselection will only changed the color only not the transparency.
-Driver is Direct3D 9.0
I fixed this problem before I THINK, before i reinstalled windows. A friend of mine that uses max has the subselection transparent, but doesn't know how.
This is annoying me so much. ( Thanks in advance to anyone that helps!
innociv is offline
Old 05-08-2008, 03:28 PM   #2 (permalink)
Realname: Andre Podolsky
Have you tried F2? it toggles the solid red VS the edges being selected. Use once you have selected a face.
SoBlance is offline
Old 05-08-2008, 04:03 PM   #3 (permalink)
Realname: Zach
Ah I think that's how i had it set up before.
That does work good enough, though it being transculent red would be ideal.
Thanks a bunch! I was getting so frustrated. :x
innociv is offline
Old 05-08-2008, 06:13 PM   #4 (permalink)
L2K
Total Awards: 2 (more» ...)
Realname: El Lu
try to play with differents combinaisons in F2 F3 F4
sometimes i have this problem, and i solve it with this trick.
Do you believe in Love?
my CG portfolio
L2K is offline
