Old 06-18-2008, 10:46 AM   #1 (permalink)
Import problems
Hi all, im trying to import a model, However im told that there are missing map file's, I've tryed editing the resorces in the path editor, striping the files names and then re-assigning, but to no end! i've tryed assigning the paths to the folder, both without success in the when im told that there are missins map file's when i try to render!, I get the model up ok.........I've searched Tutorials but they only give answers that i already have tryed!
Its like some textures decided to show some dont, One can assume otherwise that the textures may not be applied?, however i have tested this with a number of models and its the same on many that i've imported...
The format is 3ds and my software is 3ds Max
http://img206.imageshack.us/img206/7322/hammerbs7.jpg
Any ideas? or tutorials that i could be pointed to?
Lukemax
Lukemax is offline
Old 06-19-2008, 02:15 PM   #2 (permalink)
L2K
Total Awards: 2 (more» ...)
Realname: El Lu
that looks like a multi sub object with wrong polygon ID. check that.
your faces-polies have to have the same material ID than the multi sub object.
and by the way, you might want to convert all your mesh objects into editable polygon objects. believe me, it will help for the folowing.
Do you believe in Love?
my CG portfolio
L2K is offline
