| | #31 (permalink) | |
| SFM Nugget Join Date: May 2006
in any case, it's a tough nut to crack with the limited resources you have, AldrikG, and you're doing a great job so far, a nice wireframe wouldn't go astray either... | |
| Craig Bentick - Artist Pandemic Studios, Brisbane, Australia "...all you touch and all you see, Is all your life will ever be" -Pink Floyd | ||
| | #32 (permalink) |
| SFM Nugget | This work is great!!! You have done a great job on the Pegasus. I do have one small question though... I thought that the back of the Pegasus where you have the one big "engine" or whatever they want that to be, was split down the middle from top to bottom. I will try and find a picture of it and I could be wrong. Regardless I glad this is back on the boards and will be following it very closely. One other quick thing... someone asked how big Pegasus is in relation to Galactica. The Pegasus is bigger in size. This is according to an article I read on another board. Apparently this will be confirmed in the extended edition of the Pegasus episode on the 2.5 DVD set and already has been in one of the interviews with RDM. We will see if it holds true or not, but I am going to believe it for now anyways. Again great work and I look forward to many more updates. |
| | #34 (permalink) | ||
| SFM Guru Join Date: May 2006 Age: 45
| Wow! Thanks for all the comments. Ohhh!! and STARS! Quote:
The very first time you see Pegasus, it looks like she is half as tall as she is long. Other shots make her look REALLY wide. (Yes, I have been staring at screen-grabs too long!) | ||
| AldrikG Gryfalcon Shipyards | |||
| | #37 (permalink) | |
