| | #391 (permalink) | |
| SFM Guru | Quote:
Earth version(Apologies for the shaky image: It's moving fast in this shot...). You can clearly see that the Hyperdrive pyramid is gone(For obvious reasons), and is replaced with the shape shown in the post above, and the engines are radically different(I like to think the Engine tech is another Asgard gift). It also had 40mm cannons(Just under the wing root, on either side of the forward gear bay doors), and some sort of unspecified panels on the wings which have "warning" markers delineating them. It's pretty different, but it's the Atlantis version, after all. bar. | |
| Hallowed are the ORI... vipermark7@googlemail.com | ||
| | #393 (permalink) |
| SFM Guru | The episode is Fallen(Part1). bar. |
| | #394 (permalink) |
| SFM Nugget Join Date: May 2006 Location: Oak Ridge
| The Earth version looks to be from the ep. where they disabled Anubis's ship; I've got a screencap from the ep. where Tealc deploys an Asgard defensive sattellite, and one from Atlantis when the Wraith computer virus was a problem aboard the Daedalus: You can clearly see there are no cannon housings near the nose of the first fighter; the second one does have them and a substanially different structure where the pyramid had been. |
| | #396 (permalink) |
| SFM Nugget Join Date: May 2006 Age: 21
| Its probably a refit/upgrade. I just looked at the first ep of season 9 and then first ep of season 10. First a saw indeed the piramid but in Flesh And Blood i saw the 2x2 missiles and the different engine thing. Also look here. Also might be cool for someone to make a 302 with no hyperdrive. It would probably a lot lighter or some extra weapon cud be put there. Or a shield generator. The hyperdrive is pretty much useless most of the time. |
| | #397 (permalink) | |
| SFM Nugget Join Date: May 2006 Location: Newcastle, Australia Age: 24
| Head Administrator of Majestic Sci-Fi Central | ||
| | #400 (permalink) | |
| SFM Guru | Quote:
It's safe to assume, however, that every version since that didn't have the drive fitted, and indeed(As Joe pointed out), it was turned into a cargo area/Munitions deployment bay. It makes a lot of sense. And it would seem that the "Atlantis" version is now the only version... I will have to get bizzay making the new underside module. It was for that very reason, i made the Pyramid as a seperate part on my F-302 master... | |
