| | #12 (permalink) |
| Veteran Member Realname: Eric Reinholt Join Date: May 2006 Location: Pennsylvania, USA Age: 45
| Nice work PixelMagic. |
| Site: 3DSciFi.com Tutorial: How to Build the Starship Enterprise Trek: SciFiEric's The Doomsday Machine Framevoid | Scifi'ers Anonymous | Ejected Core | 4MadMen | WolfDen | Retro-SciFi | Larsen Arts | Brickhead3DArt | Oovworks | 3DSciFi Contest | |
| So, after about a four month hiatus, I've started cracking at this thing again. The reason I stopped before was because I was so frustrated that I couldn't figure out how to cut the warp grill area out of the nacelles. Well, I finally managed to figure it out, but it took me about an hour and a half to cut it out and clean up the mesh around the cut. Surely there's an easier way. Oh well. I did it anyway. There is a mesh error around the cut out of the nacelles, that I have NO clue how to fix. I just hope the panel texture maps cover it up so that it won't be noticeable. ![]() |
| | #14 (permalink) |
| Nice work PixelMagic. I don't use your software so I don't know how to help with the errors you are encountering. In TrueSpace, to get the "trough" area, I create the shape out of a globe and boolean subtract. Then I use a plane with a lot of extra points to match the circle end of the trough and create the plane. To keep from getting that artifact that runs in the front from your trough, I add a line around the cylinder to contain the error. Does any of that make sense? |
| | #15 (permalink) |
| Thanks for the advice Eric. I did what you said about adding the extra line to contain the error. I did most of the saucer section tonight. I have to add more details of course, but here is what I've got. That bridge module was tougher than i expected. |
| | #16 (permalink) |
| SFM Guru | Lookin good dude. Good to see you back on her. ![]() Indeed, the lines of the ol' gal are a bit deceiving. She's looks sO simple at first glance, but then you really start to look at her... Always try to match the point count of your curve to the point count of the perpendicular polys when cutting, or at least have the points evenly distributed. This will cut down on errors, pun intended. ![]() deg |
| | #17 (permalink) |
| Moving along quickly and very nicely PixelMagic! |
| | #18 (permalink) |
| Well, instead of updating with stills, I thought it might be cool to do it with a turntable video. Check it out at Vimeo (like an HD YouTube) ENTERPRISE_WIP_4_23_08 on Vimeo |
| | #20 (permalink) |
| Sweet! I love those types of animation. |
