Old 02-23-2008, 05:05 AM   #61 (permalink)
XRaiderV1.7's Avatar
what program's she being made with?
Universal Law #001: anything and everything that could possibly go wrong can and probably will, and, most likely, at the least opportune time. My favorite game music :KH tunes . Legends of Atlantis has a new home, HERE (click the underlined cyan colored text). SAVE JERICHO! (click the underlined cyan colored text).
XRaiderV1.7 is offline
Old 02-23-2008, 03:35 PM   #62 (permalink)
Lizzy777's Avatar
Realname: Liz Gibbs
Originally Posted by Major Diarrhia View Post
Wowzers! Great big honkin's space guns! The torp tubes look excellent, I was going to say they are too much for small ship like that but if you want this to unload all of its torpedoes really fast, then that's the way to go. One tube on the pod makes sense since it won't be able to hold as much ammo as the rest of the ship. The phaser arrays on the pod make sense but shouldn't be inset because it will reduce their firing arcs slightly. There are pointy bits to the front that overhand the inner torp tubes, they should be retracted slightly. It might be good to raise the pod slightly so the torp tube in it has just a little more clearance. Oh yeah, longer cheek phasers and a few more of them.
Total ammo count for the torpedo launchers would be around 168. There are actually 3 launchers in the pod. One fore, two aft. I actually made a "brick" of torpedoes to set inside of the different parts of the ship. That way I could get a basic idea of this thing's guts and how stuff would fit together. The pointy bits weren't in the way for the launchers' original positions. I might move them back over where they were. Still has a clear line of sight from the innermost tubes and the forward hull. Just not as much.
Or something. I'll figure out the positioning as I go along.
Those cheek phasers were a pain to build. Literally! I got a headache trying to get them to curve just right. So I'll leave those alone. ::grins:: I also plan to put a few more weapons on here. There's still the planned point defense turrets from the line art, and probably some more of those ball phasers like on the Ent-A and Excelsior era ships on the wings.
Truly a hodgepodge design! I think I'm getting that technological blend built in nicely.
Updated checklist:
- Work on the pod's exterior details
- make the red/green lights smaller
- finish detailing the engines
- work on the rest of the ship...
trueSpace 6.6
Lizzy777 is online now
Old 02-24-2008, 07:06 AM   #63 (permalink)
wow, will you release this as a .obj?
would love to see what my friend borris can do with her.
heck, once the new hardware gets here in july, I may wanna tinker with her myself.
seriously good work.
one suggestion, far as texture maps are concerned, it might be best to keep the file names down to 8 characters and under, and have the mesh file reflect this, seen a few meshes that would just not load properly due to too many texture files with long file names(3d modeling programs can be quite literal when asking you to hunt for texture map "alpha gamma blend").
Old 03-05-2008, 10:05 PM   #64 (permalink)
Lizzy777's Avatar
Realname: Liz Gibbs
I've been working on the main body bit by bit here. Finished detailing the weapon pod (not shown) and made some more details for the ship itself.
Instead of showing the little advances, I'll just show the largest part I've done so far. One of the impulse drives.
Old 03-05-2008, 10:28 PM   #65 (permalink)
Starship's Avatar
Realname: Cassio
It must have took sometime from you when cutting all those little hexagons. Looks nice.
1-Absolutelly no!!! It wonīt be done... You wonīt see a ridiculous pokemon as a crew of my ships. And donīt ask me about technobable too, please!
2- Science Fiction itīs only FICTION. Donīt argue as it is a real thing. It isnīt!
Starship is offline
Old 03-06-2008, 05:04 PM   #66 (permalink)
Lizzy777's Avatar
Realname: Liz Gibbs
Not as long as you might think. I open up the cylinder properties and set the sides to 6. Instant hexagon.
Next I array the objects on the shape I intend to cut out. Then subtract each hexagon with a boolean tool. The problem was that I originally had too many holes in the mesh and kept getting geometry errors. So I had to divide it into 4 parts and make larger/fewer holes.
Old 03-09-2008, 10:12 PM   #67 (permalink)
Jack Skieczius's Avatar
Realname: Jack Skieczius
Send a message via AIM to Jack Skieczius Send a message via MSN to Jack Skieczius
nice lizz, yo like wow nice work,
definatly got to hit you up next time i see you on AIM.
Jack Skieczius is offline
Old 03-09-2008, 10:17 PM   #68 (permalink)
kborak's Avatar
Realname: Ryan Wolfe
looking good looking good! waiting to see more.
kborak is offline
Old 03-18-2008, 07:05 PM   #69 (permalink)
Lizzy777's Avatar
Realname: Liz Gibbs
Hey Jack! I forgot you were on here.
OK, made a defense turret as intended by the original line art. Also added a transporter array, detailed the warp core/engine room dome, added a row of crew windows, and some other details to the main hull of the ship.
I based the design of the turret itself off of the TNG Type 2/3 phaser.
-edit-
After a suggestion and some simple line art, I've completely rebuilt the point defense turret. Not wanting to waste the work I did on the original (actually, it was my 2nd attempt), I reused the old turret and incorporated it into the new design.
Old 03-19-2008, 07:57 PM   #70 (permalink)
Starship's Avatar
Realname: Cassio
Cool turret!
Starship is offline
