Old 05-20-2008, 06:48 PM   #171 (permalink)
S.W.Ninja's Avatar
Realname: Gaz
I see alot of people using that sketchup these days, in some ways its good as it gives new people an easy way to doing 3D modeling
One thing I will say is you'll need a hatch of some sort for the coal bunker a decent size cargo door perhaps. Though it all depends on the level of detail you want to add
S.W.Ninja is offline
Old 05-20-2008, 06:52 PM   #172 (permalink)
cavebear's Avatar
Realname: Keith Bell
You bet! I have so much deck fittings to put in to make it come alive. Luckily I have a ton of great reference books for wooden ships and early 19/20th century iron clads. Ventilation, port holes, hatches and what not. I don't know if I will be able to come up with a satisfactory idea for stringing between the stanchions though.
Veni Vidi Visa
cavebear is offline
Old 05-20-2008, 06:58 PM   #173 (permalink)
S.W.Ninja's Avatar
Realname: Gaz
not sure if you can do it in sketchup but for low poly modeling method is to do a flat plate that spreads across your area where your rope will be then apply a rope texture with an oppacity map. When you render just the rope will be in place, however its only 2D and doesnt work well when your moving about.
Old 05-20-2008, 06:59 PM   #174 (permalink)
liam887's Avatar
Realname: Liam
Send a message via MSN to liam887
you could model a rope using the follow me tool in sketchup?
by the way when making complex models do you just make half of the ship/detail and then copy and paste it to the other side? if you dont you should start before you start adding all the details!
liam887 is offline
Old 05-20-2008, 07:07 PM   #175 (permalink)
liam887's Avatar
Realname: Liam
you can do it:
liam887 is offline
Old 05-20-2008, 07:28 PM   #176 (permalink)
cavebear's Avatar
Originally Posted by liam887 View Post
you can do it:
Whoa!!! How the heck did you do that liam887? I've used the follow me tool but it never has done anything like that for me! You have to tell me just what you did to make that knot. I also use TurboSketch and I don't remember seeing anything braided that some one didn't have to model every strand separately to get the look right. That texture is great too!
I'm humbled
Veni Vidi Visa
cavebear is offline
Old 05-20-2008, 07:30 PM   #177 (permalink)
cavebear's Avatar
Almost forgot to answer your question,
I've only done one model where I've created half and then mirrored the other half. I've never posted it though. Give me a few minutes and I'll find a pic of it and post.
Veni Vidi Visa
cavebear is offline
Old 05-20-2008, 07:35 PM   #178 (permalink)
liam887's Avatar
Realname: Liam
i didn't do it but i have done it, this image is from a tutorial when I find it on my hard drive ill post it for you to use. My hard drives full of **** and random files its about 350GB of crap but ive just got back from London this morning and realized i need a new portfolio so im deleting and sorting things ill come across the tutorial eventually in the next couple of days. If you leave the ropes and concentrate on the rest of your model you can make them when i send you the tutorial!
its ok i dont need to see it i was just wondering if you used that technique?
liam887 is offline
Old 05-20-2008, 07:46 PM   #179 (permalink)
cavebear's Avatar
Mirror image test ship pictures.
Veni Vidi Visa
cavebear is offline
Old 05-20-2008, 07:48 PM   #180 (permalink)
cavebear's Avatar
some more.
Veni Vidi Visa
cavebear is offline
