Old 04-04-2008, 06:21 AM   #1 (permalink)
Realname: Stefan Garcia
Low Poly Lego! #924 Space Cruiser
Hi all,
Looking for some critiques on how to give this thing a bit more character, and what y'all think of the idea of an "engine glow" in the rear cone. It's a game model for my Homeworld2 mod, BrickSpace. All the textures are baked on from a high poly model. I'm still not happy with the red and green pieces, they're supposed to be clear plastic.
Here's the real thing for comparison.
LEGO Set Database
-Stefan-
Sastrei is offline
Old 04-05-2008, 06:27 AM   #2 (permalink)
JeffrySG's Avatar
Realname: Jeff
Looks pretty cool. I know it's only a rocket but maybe you could add some more interesting elements that come off the body? What was the reasoning for going with the lego theme? And yes, the red and green parts definitely don't look like clear pieces.
JeffrySG is offline
Old 04-05-2008, 02:40 PM   #3 (permalink)
No to adding more stuff to it, as the reason for going with the "Lego theme" is to bring many of the spaceships shown here:
LEGO Set Database
Into a playable game world.
-Stefan-
Sastrei is offline
Old 04-05-2008, 02:52 PM   #4 (permalink)
biotech's Avatar
Realname: Rich
I used to have most of them, keep up the good work, maybe after you make the playable versions you could do high poly versions for renders.
biotech is offline
Old 04-06-2008, 04:58 PM   #5 (permalink)
Send a message via ICQ to MajorPayne Send a message via MSN to MajorPayne
Wicked stuff. I remember having the LL918 set myself. Really wish I'd have kept the ones I had though
MajorPayne is offline
Old 04-07-2008, 04:43 AM   #6 (permalink)
Major Diarrhia's Avatar
Nice. Can't you render the high res model for the texture with the clear parts actually clear with a lighting setup that exposes the clearness better? Also the top square part with four bumps should probably have a rendering that sets off the shadows around the base of each bump so they stand out more.
Major Diarrhia is offline
Old 04-07-2008, 05:33 PM   #7 (permalink)
Hehe, I was actually planning on doing just such a thing, with baking in the render. I have done so, with your suggestion in mind -much improved, I think, and the ingame effect is somewhat better than just a still can show - opinions?
As for darkening up the shadows, I will look into it. Thanks a ton, your crits are exactly the sort I'm looking for!!!
Sastrei is offline
Old 04-07-2008, 05:47 PM   #8 (permalink)
traq's Avatar
Realname: Adrian
green one looks great. red blocks still look opaque. pretty cool idea, making in-game lego models
traq is offline
Old 04-07-2008, 09:49 PM   #9 (permalink)
Yeah, the green one looks good but the red looks flat.
Always happy to give my opinion.
Old 04-08-2008, 04:15 AM   #10 (permalink)
I was defeating myself, in a way. I had the glow map cranked up to high and it was wrecking the red but not the green because of their different brightness to begin with.
I still have one more tweak I want to do, and then I'll move on to the next model, and that's just minimize the visibility of the studs under the "transparent" pieces. There's a second layer in the texture that doesn't need to be there now, with the glowmap behaving itself.
-Stefan-
Sastrei is offline
