Old 06-05-2008, 11:58 PM   #11 (permalink)
RJB
Stargate Modeler
RJB's Avatar
Realname: Ryan
Send a message via MSN to RJB
The texture map looks pretty good.
When I did my Daedalus I used a 3 shade setup, one for the base model, A 5-10% lighter one for the raised panels and then a 20-30% darker one for details I wanted to pop out.
Little things like that to give it some depth (you don't want all you detail to just blend in) and I think your more or less set.
Current Projects -> (Stargate) | USAF Excalibur | | USAF Ares and USAF Daedalus | | USAF Phoenix |
"Those who say it cannot be done should not interrupt those who are doing it." - Chinese Proverb
"The bullet of justice caps evil's ass, remember that" - Excel Saga
Calling All Stargate Fans
RJB is offline
Old 06-06-2008, 03:42 AM   #12 (permalink)
-MerlyN-'s Avatar
Send a message via ICQ to -MerlyN- Send a message via MSN to -MerlyN- Send a message via Skype™ to -MerlyN-
Its a very good start.
Some tipps to your poly count: especially on the details, nurnies and lil'gizmos watch for segmentation! a round cylindrical or spherical detail part, thats very small in comparison with the overall ship can have greatly reduced segments without anyone noticing it. For Instance, a tube on the ships hull can with good conscious be modelled with just 10 or 12 sides. No one will ever notice it.
Another crit on the texture. UVW map and texture bake your primary hull. Take teh texture to photoshop are some other fancy grafics program and add dirt and shadows and a "worn look" to the texture that corresponds to the hull panels and details. Right now the texture runs totally off track on the edges of the hangar bay. By smoothing or adding drawn details to the map in those areas you will greately improve your model.
I hope this helps a bit and you get, what I mean.
Greets,
Merl
If Windows is the solution may I please get back the problem?
-MerlyN- is offline
Old 06-06-2008, 11:33 PM   #13 (permalink)
SGA_Maddin's Avatar
Realname: Martin Steil
Thanks @ all
There are some very good Tipps.... I think I will try to drawn some special details on the big parts of the Ship like the Hangar. I will post a new version soon.
SGA_Maddin is offline
Old 06-09-2008, 11:41 AM   #14 (permalink)
Organic Mass
specs2's Avatar
Realname: Kido
Send a message via ICQ to specs2 Send a message via AIM to specs2 Send a message via MSN to specs2 Send a message via Yahoo to specs2
you've gotta be careful with the areas, that are textured with your tileable texture. for example, the runway for the 302-bays would never look like that. also, masking some parts with a slightly different texture would help, taking away that tiles look.
specs2 is offline
Old 06-09-2008, 01:53 PM   #15 (permalink)
SGA_Maddin's Avatar
yes of curse... i will create a sekond one for the special areas which dont have suth a panel/plate look... thanks for the usefull tipp.
Old 06-10-2008, 05:46 PM   #16 (permalink)
Realname: Kenneth Fredriksen
Looks good so far!! )
TreeToad is offline
Old 06-13-2008, 12:18 AM   #17 (permalink)
homerpalooza67's Avatar
Realname: Jedman67
Nice work!
homerpalooza67 is offline
Old 06-21-2008, 04:24 PM   #18 (permalink)
SGA_Maddin's Avatar
Texture WIP 3.0
Here an other Texture WIP. At the moment I try to komplete the texture and toput it on the whole ship.
Old 06-21-2008, 05:09 PM   #19 (permalink)
Davide_sd's Avatar
Realname: Davide Sandonà
Send a message via MSN to Davide_sd Send a message via Skype™ to Davide_sd
nice texture!
Davide_sd is offline
Old 06-22-2008, 01:22 AM   #20 (permalink)
SGA_Maddin's Avatar
One Year
Since exactly one year I have worked on my Daedalus and now she is almost finished. Maybe you think one year is too mutch for sutch a modell but I have started with 3d only 1-2 month before I started with the Daedalus. But I create some other modells too in this time so I dont work on the Daedalus the whole time.
