Old 05-14-2008, 02:45 PM   #31 (permalink)
GRRRRR!!!!
IRML's Avatar
SuperMod
so is this like voyager, but bigger?
I pity the fool!
IRML is offline
Old 05-14-2008, 02:56 PM   #32 (permalink)
Sensei
Deks's Avatar
Sensei
Martocticvs
I think I know what you're getting at now.
Apparently I misread in the morning.
Hm ... It's possible that what you say is correct, but I thought I took into the account the curvature when I was modeling those windows.
So it's also possible your eyes are playing tricks.
The images aren't that large after all.
But either way, I'll be sure to keep an eye on that when I'll model them on the new version.
'Somacruz145'
Nothing overly special.
I think the images of the older version came out directly out of Max actually.
I'll have to check my material and lighting settings in order to duplicate them for the V2.
But ... for the version 2, for the most part it's 99% Max and 1% photoshop (as in I only applied some color tone correction and nothing else).
We are who we choose to be and make art that defines us, but there are numerous aspects of our individuality we are born with and are an integral part of what makes us human.
Deks is offline
Old 05-14-2008, 03:17 PM   #33 (permalink)
Sensei
Deks's Avatar
Sensei
IRML
The design was inspired by Voyager yes.
I wanted to make a bigger vessel, able to accommodate virtually everything the Galaxy class had (under a smaller deck count) which would be in the Sovereign class range but more sophisticated in it's capabilities.
And it's also possible that SF would be examining techs brought back by Voyager (excluding the futuristic ones) that might culminate in a new design similar to the Intrepid class which would essentially serve as a testbed.
Akin to what the Galaxy class was back in it's day.
Deks is offline
Old 05-14-2008, 09:43 PM   #34 (permalink)
PixelMagic's Avatar
Looks great. By the way, could you post a render of your NX-01? I don't think I ever got to see it completed.
PixelMagic is offline
Old 06-29-2008, 03:21 PM   #35 (permalink)
Sensei
Deks's Avatar
Sensei
People ... a little info update.
My laptop's hard drive suffered a critical failure and stopped responding several weeks ago.
Bad news is, I lost plenty of data (including the new Nightfire mesh and my recent progress I made on the novel I'm writing among other things).
The good news is I replaced the hard drive with a new one which has 160 gb (about 2.5x larger than the last one) and I think it's possible to salvage some of the files on the old drive.
I just have to hook the old drive to the desktop computer via the proper connector (which I have) and try to read it.
The last time I tried it, Windows kept searching for a new device to no end.
I will keep trying though as I don't think the HD is that badly damaged.
The laptop I am using for most of my stuff now is a budget one I bought in London 2 years ago.
Inspiron 1300, 1.6 GhZ Celeron M, 2 GB of RAM DDR2 (upgraded from 512 over the years) and a recently replaced HD drive.
I overclocked the CPU using the pin mod so it's working on 2.1 Ghz, but the pin I used it not holding apparently and the speed is back to the old 1.6 GhZ ... will have to modify the pin a bit or use a new one to bring it back up.
Anyway ... I will start working on this mesh soon after I exhausted most of the options of retrieving the data from the old HD.
Also, I am going to the UK embassy again in about 10 days to settle the student visa (this time I'm better prepared and have even more documentation ... not that the previous documentation was insuficcient, but I thought to go there this time with a bit more just in case).
Anyway ... I will keep you updated on the progress guys.
Deks is offline
Old 06-29-2008, 04:02 PM   #36 (permalink)
kborak's Avatar
Realname: Ryan Wolfe
Hey deks listen if you cant get it to recognize it I have one little trick but it will not give you much time if it works. and if it does you wont be able to use the drive agian most likely. But if it seems there is no hope for the drive, put it in the freezer for about an hour then hook it up and try it. I have no idea how or why it works. I learned it from some who used to work at IBM for 30 years. I have done it for customers to retrieve data from dead drives more than once. But I have never gotten the drives to work agian once they die back out.
Just a suggestion. And good luck!
kborak is offline
Old 06-29-2008, 04:27 PM   #37 (permalink)
Sensei
Deks's Avatar
Sensei
I might consider that one as a last resort if everything else fails.
Thank you for the tip though.
Deks is offline
Old 06-29-2008, 06:30 PM   #38 (permalink)
traq's Avatar
Realname: Adrian
...I assume you'd put it in a ziplock bag with some salt or something to avoid moisture condensation inside?
That's an interesting trick. Never heard of anything like that before.
traq is offline
Old 06-29-2008, 10:12 PM   #39 (permalink)
This coffee tastes funny
Hobbes's Avatar
Sensei
Realname: Rick Snider
Send a message via ICQ to Hobbes
Yes, in a ziplock bag is good. It is a good trick, but should always be a last ditch effort.
Current Projects: Beyond the Red Line
There is no theory of evolution, there is only a list of animals Chuck Norris allowed to live.
Hobbes is offline
Old 06-29-2008, 11:45 PM   #40 (permalink)
Realname: Jake
Deks, you had a fighter with the original one, didn't you? I thought it was one of the coolest fighter models I'd ever seen.
Good luck with the hard drive recovery attempt, man, I know how that hurts.
JakeNess is offline
« - | U.S.S. Brussels V2 »
