| | #161 (permalink) | ||||
| Battlefleet Admiral Realname: Kitt Join Date: May 2006 Location: Australia Age: 24
![]() And thanks, the mod is going... well its going at the moment We're never quite sure where we stand at any given moment. | ||||
| Reality is like a kick in the balls, you see something you like and WHAM. FIRESTORM My Greeble Project Warhammer 40'000 team., | Warhammer 40'000 Threads thread. My planet Tutorial | |||||
| | #162 (permalink) |
| SFM Nugget Join Date: Sep 2008 Age: 23
| well as i use to post on the forums, don't rush but don't die, it will be done when its done. wouldnt the hydra's be better suited for that role, seeming as that is thier role, as i cant see hydras taking out anything as large as figthers or bombers. well maybe a shuttle. one thing that annoyed me about BFG was weapons on board, they use to say you cant use anything other than shotguns incase it pierces the hull!?!!? what the fluff states that the ships have several metres thick armour, granted the armour is simply bolted on or it may in fact be double-hulled, as some novels hint at the extreme amount of bulkheads and strengthening girders in the hull. but even so that would suggest that even the thin hull maybe what... inches thick? im sorry but not even a bolter round can penerate that, you would need the heavier weapons like, plasma, lascannons and melda's. sorry im ranting on your thread. |
| | #163 (permalink) | |
As to the worry about weapons penetrating the hull. Well that seems to be one of the things that has everyone confused. 40k Ships take weapons fire to the hull that make the nuking of Nagasaki and Hiroshima look like pop-guns yet they are always worried about internal weapons fire penetrating the hull. One can merely assume that its more a case of the worry happening near areas much less protected (exterior Airlocks etc) considering whenever you look at the fluff to do with it its always in those sections that the worry seems to be. | |
| | #164 (permalink) |
| In a tiny break from the Dagger I got this done. I got a little bit more work done on her ![]() ![]() ![]() EDIT: Don't ask about the bizarre lighting artifacts in the renders, I have no idea A: What it is or B: How the hell it happened. Even if it does look cool |
| | #166 (permalink) |
| Actually the light colours are the same, just I usually render from a Starboard view and the blue light is on the Port side of the ship. |
| | #167 (permalink) |
| SFM Nugget Realname: Eric den Biesen Join Date: Sep 2006 Age: 47
| VERY nice work! I actually had to talk my CPU into NOT commiting suicide, by promising never to do anything THIS complex. BattleFleet Gothic must havesome awesome ships if this is any example. ^_- Eric |
| | #168 (permalink) |
| SFM Guru Join Date: May 2006 Age: 25
| Very very nice, I see a great improvement over your early works. I do love the Imp Navy cathedrals in space. |
| Battlestar Galactica Diaspora Forums: http://www.hard-light.net/forums/ind...ard,175.0.html Home of Freespace 2 HLP: http://www.hard-light.net/forums/index.php | |
