Old 05-29-2008, 08:44 PM   #21 (permalink)
liam887's Avatar
Realname: Liam
Send a message via MSN to liam887
with discs removed and central core added. Close up or core to be added soon
liam887 is offline
Old 05-29-2008, 09:01 PM   #22 (permalink)
liam887's Avatar
Realname: Liam
here is a close up of the central core which has replaced the disk sections. In here the power core is located as well as crew quaters, material storage etc etc. I took it from this angle so it would fit on the render. It stands up vertically on the model. Also a view from sketchup showing just how tall it is!
liam887 is offline
Old 05-29-2008, 10:39 PM   #23 (permalink)
Dr Lee's Avatar
Realname: Rob
VERY cool!
Angel's Reach
CASF
Don S Davis 1942-2008. Godspeed and thank you
Dr Lee is offline
Old 05-30-2008, 01:43 PM   #24 (permalink)
liam887's Avatar
Realname: Liam
Here is a close up of the end of the core. The 12 arrays at the bottom move about of thier own accord to recieve maximum efficiency thats why they are not all in line. There are two cruisers docked at the bottom (Marathon Class & Halycon Class). Raw material is brought up from the moons surface on the elevator. Unfortunatly you cant see the cables properly due to the poor rendering engine.
liam887 is offline
