Old 06-11-2008, 02:10 AM   #81 (permalink)
Monkey Boy's Avatar
Realname: Andrew
Originally Posted by S.W.Ninja View Post
@ Doc doesnt seem much point of torpedoe tubes as in space direction doesnt matter to much, so whether the tubes are vertical or horizontal I dont think it matters. The missile tubes that are behind the forward guns are reloadable within the ship. Also the rear turrets are capable of firing directly behind the ship and there is a set of rear CIWS covering the engine exhausts from Heat Seaking missiles. Thanks for your comments though mate
There is some wisdom in launchers facing in all directions, if realworld physics is applied, then if all the launchers are placed on the top deck, then to target an enemy in front of you, the missile first has to cancel it's delta V vertically after launch then accellerate forwards to the target. Tubes facing in all directions gives the option to use the initial boost from launch in the direction of the target, and all of the missiles fuel is used to accellerate to that target, none of it has to be used to stop the missile going one way before heading the other.
However you would be indanger of hedgehogging your ship with spherical coverage of launchers, and it would look less cool.
Great work so far, I'm loving this project: The marine hatch at the rear of the superstructure is a particularly nice touch!
Cheers,
Whenever you find yourself on the side of the majority, it is time to pause and reflect. - Mark Twain.
Monkey Boy is offline
Old 06-11-2008, 05:49 PM   #82 (permalink)
S.W.Ninja's Avatar
Realname: Gaz
Okay been playing with the hull today giving it some details also employed some of the dock workers to start texturing the superstructure
S.W.Ninja is offline
Old 06-11-2008, 06:21 PM   #83 (permalink)
Berkut's Avatar
Realname: Bogdan
looking good, I think it could use some of those launchers in the sides in the "cracks" between the top and bottom hull. Would make a nice broadside, hehe
Berkut is offline
Old 06-11-2008, 08:21 PM   #84 (permalink)
S.W.Ninja's Avatar
Realname: Gaz
Okays well I think i finally crumbled to the temptation and added forward launch tubes. Not detailed them up fully as yet just roughed in but I think im happy with how they look so they'll be staying. Proof I really do take comments on board so keep em coming
Old 06-11-2008, 10:15 PM   #85 (permalink)
Monkey Boy's Avatar
Realname: Andrew
Wow, they are heavy duty forward topredos!
You are not going to have a lot of room inside for reloads though.
But, I do like 'em.
Old 06-11-2008, 10:42 PM   #86 (permalink)
Berkut's Avatar
Realname: Bogdan
yeah, those practically look like space station killers, good stuff
Berkut is offline
Old 06-11-2008, 10:56 PM   #87 (permalink)
S.W.Ninja's Avatar
Realname: Gaz
There actually a bit mis guiding size wise, as the actual tube diameter is the same as the vertical missile tubes. Im planning to maybe do an interior for this once the exterior is done to so its going to be fun fitting it all in.
Old 06-13-2008, 02:03 PM   #88 (permalink)
Carach's Avatar
like the new look of the bridge area
Carach is offline
