| | #111 (permalink) |
| SFM Guru | lol, well the magnetic gun module is pretty overkill, its pretty huge (takes up 2 hardpoints), I haven't measured it yet so don't know the exact caliber, but a direct hit would probably demolish a mech, if you hit a tank with that you probably wouldn't be able to find much of it, but it has very limited ammo due to size and a slow rate of fire because of the heat, so you probably wouldn't use it for anything less than a mech. The anti mech missiles are even bigger, and would definately trash a mech with one hit, but they are vulnerable to active defences. |
| | #114 (permalink) |
| SFM Guru Realname: Kervin Abbott Join Date: May 2006 Location: Houston Age: 33
| Nice detail, |
| To find some pretty good, free and inexpensive software applications, as well as other stuff, click here. | |
| | #116 (permalink) |
| Ha drool, do I see infrared decoy emitters, smoke grenade launchers? I loooove the sensor suite! Beautiful! I never really got into mecha, myself (apart from the Eva from NG:E, which as Manga, doen't really count), so I don't really have the right to comment on the overall design, but I know it has been mentioned about balance and the reducing number of toes, but the pounds per square inch these narrow feet must place on the ground would be huge, hope it doen't run across any soft earth or swampy ground! |
| | #117 (permalink) |
| SFM Guru | thanks dude. I highly doubt it would be a problem as it is, but either way I'm trying to add the 3rd toe back in now. I don't see this as being a serious problem anywhere where normal vehicles can travel now (swamps would screw anything over, even this thing), I mean look at humans, we have very small footing area when compared to our weight, yet we don't exactly fall through everywhere. Besides if it ever gets into crap it can use the boosters to kinda jolt itself out |
