| Forums | Downloads | Gallery | TOS | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| | LinkBack | Thread Tools | Display Modes |
| | #21 (permalink) |
| SFM Guru Join Date: Jul 2006
Downloads: 0 Uploads: 0 ![]() | Rigging sucks...
__________________ My shameless plug: www.dragonboltstudios.com |
| | #22 (permalink) |
Downloads: 0 Uploads: 0 ![]() | Alrighty, got the rigged legs in place and trying out a base texture (may or may not keep it).
| | #23 (permalink) |
| Cat-Herder Extraordinaire Join Date: May 2006 Location: Leuven, Belgium Age: 32
Downloads: 2 Uploads: 0 ![]() | Looking good to me, I especially like the eyes/windows. The weathering could use a bit more clever placement though, y'know more around the edges and other parts that are likely to be chipped and scratched. Now it seems a bit too random.
__________________ Latest WIP - SSV-CEC Anubis WIP - Forgeworld Space Marine The Man Who Saved The World Last edited by Meph; 07-04-2008 at 03:09 PM. |
| | #27 (permalink) | |
| SFM Nugget Join Date: Aug 2006 Location: Seattle WA USA Age: 42
Downloads: 3 Uploads: 1 ![]() | Quote:
Rigging Hydraulic Pistons in Lightwave | |
| | #28 (permalink) |
Downloads: 0 Uploads: 0 ![]() | Meph - as it currently stands the mapping is all temp. Right now what's on there is a simple tileable grunge map. I'll be doing custom grunge and scratch maps, tho I really need to decide what the base texture is (Right now it's a generic metal texture map that I have) efritsch - Thanks! Zhor2395 - Thanks! You could also direct 'em to the Rifter Zero. It's a pdf put out by Palladium (costs $3) and I did about 90% of the illos, all 3d...(hehe...couldn't stop myself from doing the shameless plug )gthompsn - Thanks! Glad you like 'em ![]() DaveWh - I think it's a great tut, easy to understand and follow! That actually was the first method that I ever used for pistons, and it works great when you're dealing with a ball and socket joint. The issue I had with using targets was simply that despite the axis limit panel, the damn things never took into account which axis were to be used and which weren't. If I was creating a piston which had only one axis of movement due to the connector, using a Target method just had a hard time keeping the connector from spinning on it's axis and penetrating the point of connection. I wound up using a simple IK method, just adding a null on the end of each of the piston pieces and setting the nulls to use IK goals, then using both the axis channel limitations (In the case of the SSW's legs, the pistons only use the Bank Channel) and I've generated bank limit's on the leg pieces themselves to simulate the effect of the piston length limiting their compression and expansion. In some cases, such as with an arm I had to do which involved ball and socket connectors and required movement on all 3 axis, I use a blended method, usually involving having the smaller, "Male" piston segment to use targeting and the "Female" segment to use IK. In the end, tho, it's all in what you need, and your tutorial definitely does a good job of giving people, especially those scratching their heads without a starting point, a solid base to use and to grow from. So I say unto you: Good Job!!!
| | #30 (permalink) |
Downloads: 0 Uploads: 0 ![]() | Here's a quick update, custom grunge and paint chip maps applied to the front of the skull thus far, the rest are generic. The dirt itself is an accessibility shader using a custom grunge map to control where the dirt will show up.
