| | #521 (permalink) |
| SFM Guru Join Date: May 2006 Age: 35
Downloads: 1 Uploads: 0 | Even that small fragment really does look damn fine |
| DU Admin || Gert Lush Modeller|| Ex SFA Senate i unzipped, loaded, F9'ed, went "arrrgh!!!" and closed.......Finish???? Nobody said anything about finishing!!!!!! | |
| | #522 (permalink) |
| SFM Obsessed | Interesting ship, I like it. |
| He's a high-tech redneck, Mayberry meets Star Trek. He's a bumpkin' but he's plugged in, he's a high-tech redneck. -George Jones Death and Limbo Icon 3 | |
| | #523 (permalink) |
Downloads: 0 Uploads: 0 | The gray lines are gaps between hull panels. They have already been cut into the mesh and will eventually be recessed to match the ones on the underside. I'm presently working on these kinds of details all over the ship. The next stage after that will probably be windows. |
| | #524 (permalink) |
| SFM Nugget Realname: Darren R. Sexton Join Date: May 2006 Location: The Glorious South (USA) Age: 42
Downloads: 4 Uploads: 0 | Well, it looks great! Do you have a texture guy or do you still need my help with that? PS- I sent you an email twice, did you get that? Please read that. I'm trying to get the bridge CGI started with Elowan and also the Blackfoot needs desperate fixing so Smallworld has agreed to help out. |
| theCommander 1st Officer & Original designer of the USS Grandeur / USS Grandeur-A >>> Check out my CGI schematics at:Darren R. Sexton's Drafting Tablet | |
| | #525 (permalink) | |
| SFM Obsessed | Quote:
Ca I ask you a little more? Just curious about the way you do it. ![]() Were they shapemerged or a manual cut? Still in this line: the windows will be shapemerged, cut one by one, or just managing specific pollys with bevel? kinddest regards! | |
| My Page - http://starships.host.sk/index.htm 1-Absolutelly no!!! It won´t be done... You won´t see a ridiculous pokemon as a crew of my ships. And don´t ask me about technobable too, please! 2- Science Fiction it´s only FICTION. Don´t argue as it is a real thing. It isn´t! | ||
| | #526 (permalink) | ||
Downloads: 0 Uploads: 0 | Quote:
| | #527 (permalink) |
Downloads: 4 Uploads: 0 | Hmmm... could you check again... I emailed you twice and it was relative to the hangerbay that the Blackfoot sits in... I need measurements and a closeup view or two with a scale something sitting in it ...would help out quite a bit if you could swing it. Smallworld and I are working/fine-tuning the Blackfoot for height, armor plating, and other stuff... like a good working model... LOL instead of that other one... |
| | #528 (permalink) | |
I actually agonized over this step in the process for quite a while. One of the reasons this project has been dormant for so long is because I knew what I wanted to do but I had no idea how best to accomplish it. I thought about modeling the hull plates individually using Sub-D's or spline cages or even NURBS, but I kept running up against massive polygon overkill and problems with the curvature and alignment of the plates. In the end, simply cutting the gaps into the existing mesh seemed to be the least objectionable method. As for windows, I will probably use pretty much the same method, although some further subdivision of the polygons that contain the windows will probably be required to avoid long, skinny triangles and the smoothing distortions they cause. Once they are cut, I will extrude them inward, probably without any additional beveling. I find that beveling window edges on a ship this size just isn't worth the effort unless your doing some very closeup renders, in which case I'd be more likely to build a special-purpose, high-detail model of the hull section in question rather than do the whole ship that way. Also, I may wind up saving the windows until the very end to better facilitate the process of converting the mesh into a 3D printed physical model. Apparently details like windows are better added by hand after the basic parts have been mastered. | |
| | #529 (permalink) | |
There is no bay as such, just the doors and the surrounding exterior structure. I can tell you what the dimensions of the bay opening are and I can probably give you an idea of its maximum depth once I get home and have a chance to take the measurements off the model. By the way, what I had in mind for the Blackfoot's docking bay is a bit different from the typical, TNG-era, box-like Federation starship hangar bay. I'm not envisioning a floor as such but rather a kind of alcove surrounded by form-fitting structural ribs. The Blackfoot wouldn't actually "land" in this bay, it would probably be grabbed by a pair of extensible docking arms and retracted into the bay. The Blackfoot is more like a runabout than a shuttle and I just think it needs a more robust connection to the mothership. They don't call it a "docking" bay for nothing. Just my thinking on the subject. Your milage may vary. | |
| | #530 (permalink) |
Downloads: 4 Uploads: 0 | Okay, well please give me clearance numbers so that we don't scrape the top of the ship when she gets pulled in. Brian wants to add some thickness to the front of the BF so that we can actually have thew bridge that NS designed so graciously for us... so we'll need those dimensions, please sir. Also, FYI - the BF is about three-four times the size of a runabout as she stands right now. ![]() |
| theCommander 1st Officer & Original designer of the USS Grandeur / USS Grandeur-A >>> Check out my CGI schematics at:Darren R. Sexton's Drafting Tablet Last edited by theCommander; 03-26-2008 at 10:58 PM. | |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| joelcann |
