Old 09-24-2006, 08:47 PM   #101 (permalink)
Dan
Dan's Avatar
Realname: Dan Bryant
I presume you mean on the underside, I've hidden it with a panel. And does anyone know how to get rid of these black things in my render?
EDIT: It's OK, I've figured it out. There were duplicates underneath after using the Spin tool in Blender.
Dan is offline
Old 09-24-2006, 09:07 PM   #102 (permalink)
Dallidas's Avatar
Realname: Kyle
erm, you shouldnt just cover it up, i can still see it. just use the remove doubles function and you should be fine.
Dallidas is offline
Old 09-24-2006, 09:37 PM   #103 (permalink)
Dan
Dan's Avatar
How do you do that?
Update, with a couple of engines that I've done in a similar style to the Daedelus's.
Dan is offline
Old 09-24-2006, 09:47 PM   #104 (permalink)
Dallidas's Avatar
Realname: Kyle
in edit mode and all vertices selected press W--->remove doubles. or its in the mesh edit tools tab
Dallidas is offline
Old 09-24-2006, 10:38 PM   #105 (permalink)
Dan
Dan's Avatar
I've tried that, it said there were no doubles, I've tried several things, nothing's worked fully so I'll leave, it's only a small part and hardly noticeable unless the camera is on it. Thanks anyway.
Dan is offline
Old 09-26-2006, 09:27 PM   #106 (permalink)
Dan
Dan's Avatar
Here's an attempt at a new hull, I'm no so sure about it, what do you guys think?
Dan is offline
Old 09-27-2006, 02:25 PM   #107 (permalink)
Elowan's Avatar
Too early to really tell IMHO.
Elowan is offline
Old 09-29-2006, 08:20 PM   #108 (permalink)
Dan
Dan's Avatar
Ok, update with several images. C&C please.
Dan is offline
Old 09-29-2006, 09:31 PM   #109 (permalink)
Bar
Bar's Avatar
Send a message via MSN to Bar
It looks fine, but if i'm really honest, i don't think it has enough of a "face".
It needs a striking look at the front to make it look a bit better.
I like the pylons connecting the flight pods, though. Really nice.
Bar.
Hallowed are the ORI...
vipermark7@googlemail.com
Bar is offline
Old 03-08-2007, 02:02 AM   #110 (permalink)
bsg recon's Avatar
Send a message via MSN to bsg recon
Any updates ship looks awesome
bsg recon is offline
