| Challenge 006 - The Chair [ARCHIVE] This is the archive for the sixth Sensei challenge entitled, "The Chair". |
| SFM Nugget Join Date: May 2006 Location: Germany Age: 25
| Challenge #6 – Ronin – Navigation & Control hi, my first try on a Challenge ![]() This one is desired to be a Navigation & Control Chair of Ancient Starships of the Universe i call Alveon. Those Ships are navigated half by brain, half by visible and touch-interface. The Navigator can display charts / diagramms / sensors as hologramms. All Hologramms are interactive and recognize "touch". ok, so far about the story/background, back to the Challenge:i want to create a bit of sourrounding floor in Stargate Style...maybe ?! - testing that on the first render. It should be 'usable' for quite some time without break and without hurting oneself / needing a pain-blocker medication ^^ .... so it will have cushions. I'm not good enough to do any sketch/draw by hand, so i went to 3d/render directly. With luck, there will be a bit of a holographic /transparent starchart around / in front of the Chair...for now i don't know how to archieve this...but i'll try. |
| decided for a more round look for the surrounding floor, but actually don't know to get a more deeper, a bit deepwater-look into that blue-areas. Added fixed displays to the second ring. There will be one on each side, maybe a second pair coming down. All displays are planed to be textured later. Next step: - testing / adding more solid parts, making it bigger, more massive. - testing modes / which parts will be able to move / rotate |
| Its alot like a trek command chair, but the holographics are a nice touch |
| Headerizer Realname: Matthias Zabiegly Join Date: May 2006 Location: Munich / Germany Age: 27
| Just to remind you - for this challenge a design sketch is required. Good start! Keep it up |
| You ain't seen nothing yet http://www.zabiegly.de | |
| Zabiegly, thanks for reminding. but just re-read the rules, what do you mean with 'sketch'. My Startup/Concept is attached to the First Post. This is my first Challenge, so i might have not completly understood some of the rules ?!?! added three renders, this is my first try on transparent textures. so i added alpha and some color-test. I Removed a third Ring of Holographics for a better view on the Chair itself. The sphere in front of it, is the basic holographic projector for Starcharts. Currenty i'm thinking of modifying the Concept ..maybe a bit to a more tank / anti-gravity Chair. But in an anti-gravity environment, why adding a chair at all ? |
| | #8 (permalink) | |
| Nice environment - the darker lighting on the background brings the chair out nicely. Some Ambient Occlusion and maybe global illumination / final gathering will make for an even cooler render ![]() This is the section I was refering to: Quote:
As you already started your chair without sketching maybe you could make a sketch of a detail you want to add? Maybe sketch a controll panel before you model it? | |
| You ain't seen nothing yet http://www.zabiegly.de | ||
| | #9 (permalink) |
| ah, thanks. There is already a rough sketch from the beginning, i just didn't know it would be required. Question: is it alowed to make a second attempt ?, i want to make a test placing the Chair into a antigrav-tank and than decide which one will be used further. How about a basic-Human figure in the Chair ?, transparent maybe i got some kind of implant in mind, which will be connected with the chair by cables... thanks Edit: just added my sketch, had to make a picture with a camera, so it's not the best view. i'll upload my scetch of the tank as well, as soon the 3d-Concept of this is done. |
| | #10 (permalink) |
| so, i tested the Antigrav-Concept...now i don't know which one i like more. The Chair has a bit of gravity-pull, so the navigator is not floating around all the time. The Controls at the Arm-Parts can be moved up and down to fit however the Nav wants to have it. i added my sketch of this as well. Normally i don't make sketches, but this time they are very useful for the Shape of the Chair / pose of the user and the basic skale. i'll continue with texturing the displays, those are equal in both concepts. Related to the Challenge, the AG-Concept is a bit more uncommon. What do you think of it ? |
