| SFM Obsessed Realname: Leon Join Date: May 2006 Location: Berlin Age: 18
| Yep. You can easily disable it in the User control whatever, but I wouldn't recommend it. There are some "tutorials" on how to make it less annoying though, maybe that's worth a try? |
| SFM Guru | you Can turn off UAC in msconfig. but be aware that without UAC certain apps like viruse and firewalls won't be able to elevate themselves Also, after you get past installing your usual apps you probably won't see it again anyway very much. Even for installing apps, more and more apps due to vista is now learning not to make bad installers that assume adin right(somethign that has never en required on NT based systems, that's only ecause of bad programmign of installers and application developers) |
| HawkMan Worlds Beyond Darkness - Your universe, and ours Help create a unique and diversified universe, only creativity is your limit Last edited by HawkMan; 09-20-2007 at 12:52 AM. | |
| This time you see | Meh, as a Mac user, I'm used to having to verify the admin account with a password every time there are major changes made to software- The security gained is worth more than the convenience lost, generally. |
| Here comes the water, It comes to wash away the sins of you and I. This time you see- like holy water, it only burns you faster than you'll ever dry. | |
| | #8 (permalink) | |
| SFM Guru | Quote:
But I haven't installed either and I do run with UAC off. But it's not something I Reccoment others to do. I may also stop running with UAC off. It's important to remember that UAC isn't the only security measures taken with Vista, BUT it is an important one as no OS should ever be run as admin(root), and UAC is there to allow you to do stuff that requires admin without being one. As I allready said, UAC prompts will go down as more vendors start coding there software correctly to not require admin access. But even so, you need to remember that even if an app is coded correctly, installing it to a location you don't have access, wich usually mean you shouldn't be savign stuff there or installing stuff there, will give an UAC prompt no matter since you user has no rights. With people that upgrade and use separate folders outside of user space to install apps to this is more likely as these folder probably reatain user rights from prevous windows versions. | |
| HawkMan Worlds Beyond Darkness - Your universe, and ours Help create a unique and diversified universe, only creativity is your limit | ||
| | #10 (permalink) |
| SFM Nugget Join Date: May 2006 Age: 28
| There are settings other than "on or off" - as someone earlier suggested do some research through Google and you'll find a tonne of information on how to configure UAC to suit your needs. Like Hawkman said though, turning it off entirely isn't advisable unless you are tech savvy and run a tight ship. It's there to help after all. I never got my head around why in previous versions of Windows users were generally admins unless put onto a limited account. Leaves programs free to do pretty much whatever they like. / Possibly the cause of so many of the security flaws that plagued / plague XP? As for the poorly written software - I guess having the free reign that users-as-admins provides has let them get sloppy with coding. Hell, I'm STILL surpised how many application don't handle multi-user environments very well. Seems crazy, and a nightmare when trying to put together an image for deployment. |
| "At the age of six I wanted to be a cook. At seven I wanted to be Napoleon. And my ambition has been growing steadily ever since." - Salvadore Dali | |
