Go Back   Scifi-Meshes.com > Requests Area > General Requests
General Requests Whether you're looking for reference materials, that elusive mesh or something more exotic, this is the place to ask (nicely!).
Old 04-12-2008, 01:47 AM   #1 (permalink)
K'Vort Idea
I had thought of an idea but never quite got around to drawing it up of a K'Tinga with it's wings swung-forward with a few design changes.
1.) The D-7M's center-wing section is taller and wider in the front than in the back. I had tried to mirror this on my computer before and I saw this. To produce an effect more like an old Romulan-BoP which has forward swept wings, the best solution was to retain the heights at the front and aft, but change the widths to be closer to each other (front is still wider than aft)
2.) The hammerhead (and the ball shaped structure underneath that house the torpedo-tube) need to be scaled up a little bit as the K'Vort is 350 meters and the K'Tinga is 214 or 228 meters (Either way the torpedo tubes, fore and aft should be the same size, and I see no reason why the bridge should be bigger.)
3.) More streamlined nacelles
-Nacelle-pod leading-edge swept aft (from top to bottom)
-Nacelle-pod trailing-edge swept forward (from top to bottom)
-Nacelle-design tapered (shortened a bit at the front and narrowed a little, heightened a bit in the middle, possibly widened, shortened a bit in the rear, narrowed down a bit over there)
I probably could have done it awhile back, but unfortunately the new computer I have doesn't have the graphics program I'm used to using, plus I'm out of practice...
Either way I'm wondering if anybody could help with producing a 2D drawing that I could use of such a design.
CuttingEdge100
CuttingEdge100 is offline
