Poll: Do you like ice-cream
Poll Options
Old 07-12-2006, 06:04 PM   #101 (permalink)
Roliba's Avatar
Thanks for the images fish. Ironically, I've posted the same link in another one of my threads. As soon as I remembered that, I found the same dern pictures.
So back to work...
First I selected the faces I going to be working with, extruded them inward a touch, and seperated them.
Then I cut some evenly spaced edges into the newly created object (after counting the number of grooves I wanted)
Then I cleaned out all of the old edges. Doing this left me with some weird geometry issues (or I just noticed them ) at the rear of the cutout on the naccelle, so I took this as a good time to clean them all up.
Then I select alternating linear poly groups...
..Inset them...
...and pulled them back about 6 inches.
From there, I selected the object placed an dark material on it execpt for some of the sunk in polys which got a blue glowy material. Then I rendered...
Roliba is offline
Old 07-12-2006, 07:42 PM   #102 (permalink)
Oovebei's Avatar
Realname: John
Looks like I am going to have to improve my movie nacelles (Drat, Damn, Blast, Cry)
Damn good tut tho
Who is the more foolish - the fool, or the fool who follows them?
Oovebei is offline
Old 07-12-2006, 07:49 PM   #103 (permalink)
Roliba's Avatar
Damn good tut tho
Thanks Man! I'm glad you like it.
I'm going to render a pinky glowy one later (as per TMP), after work.
Roliba is offline
Old 07-13-2006, 06:28 AM   #104 (permalink)
Roliba's Avatar
Moving on to the otherside's grooves...
First I used Quick slice to cut a whole SH**T load of horizontal edges in the second blank indent
Then converted the selected edges into a bunch of parralell splines that just happened to follow the contour of the indent using "Create Shape From Selection". Once I had my now multi-line shape, I deleted the indent as no longer needed.
Then I made the splines renderable with a 7" inch thickness. (Note: I spaced the sliced lines 6" apart when I cut them. With them now 7" thick "sauages" they will overlap.)
From there it was just a matter of splashing on some color. (I also made a glowing bit to simulate the little bright light that exist on the model.)
Roliba is offline
Old 07-13-2006, 06:36 AM   #105 (permalink)
Roliba's Avatar
As I mentioned earlier, I wanted to render it out with the purplely-pink glow from the Motion Picture. I'm not actaly sure when and even if the inboard thing went blue, but I've seen a lot of images with it blue. So anyway, here's a comparison of the two.
Opinions?
Roliba is offline
Old 07-13-2006, 07:14 AM   #106 (permalink)
Roliba's Avatar
Next, I'm going to build the paylon mount.
It starts its life as a spline circle pulled into the correct shape.
Then I convert the spline/circle into a poly and extrude into length.
Max has a wonderful little tool for poly editing: Hinge Polygon From Edge.
I selected the end cap poly and applied the mod, Hnging the poly 90 degrees and with 12 segments (not the 6 shown in the picture).
Did the same to the other side and pulled the caps into their final shape with FFD boxes, for a final touch.
Well gang, that about covers it. From here on in you can add as much extra detail as you want (and there are quite a few little bits scattered about) and whatever texture you need. However, as far as this tutorial is concerned, I believe I've covered all the major points.
If any thinks I might have missed anything, please speak up and I'll deal with it.
Thank-you for your attention and your support.
This is not the end though. Keep the occasional watch here, because I will be doing the rest of the ship... soon... starting with the fantail and Hanger deck (These are not the droids I'm looking for...).
Untill then I leave with one more image of the finished (mostly) naccelle.
Roliba is offline
Old 07-13-2006, 10:40 AM   #107 (permalink)
Veteran Member
scifieric's Avatar
Realname: Eric Reinholt
Congratulations Roliba! That's a great tutorial!
scifieric is offline
Old 07-13-2006, 11:49 AM   #108 (permalink)
ns_exile's Avatar
Realname: Don
Send a message via MSN to ns_exile
Damn, very nice, Roliba. If I get the time today, I'll update the PDF file, send you the changes, and we can figure out if it needs tweaking or sprucing up.
"It is so easy to complain about the weather or the taxes in Canada but move away and you'll find yourself complaining about the airfare to get back."
- anonymous
ns_exile is offline
Old 07-13-2006, 08:14 PM   #109 (permalink)
Starship's Avatar
Realname: Cassio
I´m posting just to say THANKS !!! I´m learning a lot from this thread.
Keep doing the great work !
Starship is offline
Old 07-13-2006, 11:32 PM   #110 (permalink)
Is Baaaaack...
Jedilaw's Avatar
Realname: Casper Del Blanco
Truly outstanding work, mate.
Jedilaw is offline
