Old 09-05-2006, 10:21 PM   #21 (permalink)
call me Roman
limdaepl's Avatar
Tutorail Writers Award Tutorail Writers Award
Total Awards: 2 (more» ...)
Realname: Roman
Send a message via ICQ to limdaepl Send a message via MSN to limdaepl
Here's my tip: Select those edges which you're not sure if you should make them hard or soft. Choose extrude but extrude them by the amount zero. do this by pressing tab and enter a numeric value because you also need to choose a quite small radius (experiment a bit)
This will not alter your geometry but it will produce those extra loop lenno was talking about both on the phaser stip and on the hull. The one on the phaser strip can be removed as it is not necessary.
This should help.
Regards Roman
limdaepl is offline
Old 09-05-2006, 10:25 PM   #22 (permalink)
Sensei
LennO's Avatar
Sensei
As I said, all you need to do is to add the appropriate loops.
take a look at the attached pic:
1 and 2 show what you currently have, with the normals producing shading artifacts. This is because they are smoothly interpolated (soft normals) over a large polygonal area.
Hardening (3&4) of course will get rid of the shading artifacts, however, as you said the hard edge doesn't look very natural.
The solution (5&6) is to add to additional loop, forming a 3 edge bevel, wish will give correct normal smoothing, and appear as a bevel. Of course in it's current state it doesn't look exactly nice, but this is because the phaserstrip is somwhat lowpoly.
I am not sure whether this mesh is meant to be subdivided, if it is, the correct beveled edge (or better–correctly looped edge) will give better results (7) as opposed to the way to organic shape your original layout would produce (8). Vary the edge distance to control the bevel size for both subd and not-subd.
I wouldn't suggest an extrusion by zero as this will produce VERY hard to clean up areas. In fact you'll have double edges, hard to spot if you need to do any modifiaction on the part and a pain in the ass really. In some apps this will even produce doubled polygons in certain areas so your better of adding a loop using a loop cut (which works in this case) or manually.
LennO is offline
Old 09-05-2006, 10:27 PM   #23 (permalink)
call me Roman
limdaepl's Avatar
Realname: Roman
Originally Posted by LennO View Post
*answering*
I was faster nevertheless
limdaepl is offline
Old 12-25-2006, 05:25 PM   #24 (permalink)
Ozylot's Avatar
2nd Place Award - Sensei Challenge 5 Sensei Challenge Honorable Member Award
Realname: Carl
Cool
Here is a quick little one...
It demonstrates the use of the bend command. Makes pipe work very simple.
STEP #1:
To start you will need a set up like this.
created by selecting the edges, cutting into 5 segments and connecting the loose verts.
STEP #2:
The first thing the bend procedure requires is the rod center, seems to work well when you pick a point on the side of the bend.
once selected, right click to advance to the next step.
STEP #3:
Next, select a point at the top end of the pipe, make sure its on the same edge as the first point was.
STEP #4:
This can be done a number of ways from here, you can select a face, edge or vertex to do this. In this example ive used a vertex to set the bend direction. a small arrow will appear to indicate the direction.
STEP #5:
At this point the pipe will be able to be bent freely as you move the mouse. Keeping an eye on the number in the top left of the screen will allow you to bend the pipe to precision degree amounts.
Hope this helps, so you don't get all bent out of shape in making pipes. ;D
- Ozy - A proud supporter of 3DScifi.com and SciFiers Anonymous
Current WIP: My site (Notepad :D )
Old Stuff: Gallery pics and wips...(Wings3D, Kerkythea & Bryce)
Ozylot is offline
Old 12-26-2006, 04:26 PM   #25 (permalink)
The B5 Fan's Avatar
Realname: Andrew
There's a bend command?
The B5 Fan is offline
Old 12-26-2006, 04:39 PM   #26 (permalink)
Ozylot's Avatar
Realname: Carl
Yes, you need to activate the advanced menus in the properties to use it.
Ozylot is offline
Old 12-30-2006, 04:54 AM   #27 (permalink)
Completely lost...
Lord Ravensburg's Avatar
Realname: Lee
Location: Find the A$$ end of nowhere and i'm just north of it...
Send a message via AIM to Lord Ravensburg Send a message via MSN to Lord Ravensburg Send a message via Yahoo to Lord Ravensburg
Sweet!
Keep smiling , It makes people wonder what your up to..
Some Cool Sites: 3D Scifi | Framevoid | Scifi'ers Anonymous | Ejected Core |Wolf Den Productions
WIP: Assault Frigate
Lord Ravensburg is offline
Old 02-24-2007, 02:07 AM   #28 (permalink)
Ozylot's Avatar
Realname: Carl
New Tutorial time!! ;D
This one demonstrates the use of several of the advanced commands which are accessed by right clicking on regular commands. Probably the most useful of these is the advanced flatten command.
so lets begin:
We are starting off with an irregular shape, could be an aircraft intake or something, but it will be an interesting vent when were done.
1) Switch to edge mode by clicking on the appropriate icon at the top of the screen or by pressing 'e'. We are going to cut the edges into 10 sections using the cut command. (this can also be done by pressing '0') You will automatically be switched to vertex mode, with the new verts selected.
2)We are now going to create new edges between these verts by using the connect command (can also be done by pressing 'c')
3)Now switch to face mode by using the icon at the top or by pressing 'f'.
next we select the new faces that have been created. There should be 10 of them. We now inset the selected faces by about 70%.
4)At this point we are now ready to use the advanced extrude command. Right click on extrude. (it is important to pay close attention to the info bar at the bottom of the geometry window when using the advanced commands. The text there will guide you through the process)
5)The first thing that the advanced extrude command asks for is a direction to extrude along. as you can see here I have selected an edge for this. A small blue arrow indicates the chosen direction.
6)After extruding the new parts beyond the outer face, we are now ready to use the advanced flatten command. For this procedure you need to hold down Ctrl while right clicking on the flatten command.
7)The first requirement of the advanced flatten command is a direction or normal. As you can see here I have selected the lower face of the object, however in some situations it could have been better to select one of the extruded edges. Right click to accept this selection.
8 )Next thing the advanced flatten asks for is a reference point for the selected faces to be flattened to. Again I have selected the lower face on the object.
9)Had I used a different reference point on that last step I could have avoided this, the slight amount of overhang from the extrusions can be corrected by a simple Move>Normal
10) and this is what we are left with. I hope you have learned something useful
Ozylot is offline
Old 02-24-2007, 10:35 PM   #29 (permalink)
Blender 2.46
Forcemaster2000's Avatar
Realname: Chris
Send a message via MSN to Forcemaster2000
Wow! You guys make wings3d much cooler looking than I thought it was!
Forcemaster2000 is offline
Old 02-25-2007, 06:30 PM   #30 (permalink)
The B5 Fan's Avatar
Realname: Andrew
I was sure I'd already replied to this but anyway:
Nifty. It looks to be better than the simple way I use.
