Old 04-22-2008, 01:55 AM   #101 (permalink)
hmmm, need some suggestions. still seems to be a little weird... but i cant figure out whats wrong with it?
edwardgtxy is offline
Old 04-22-2008, 02:59 AM   #102 (permalink)
Realname: Robert Rose
bump/normal mapping seems insanely high and I'm not sure if the other bumps are supposed to be the clouds or not. if thats the case you either missed out on the defuse or opacity mapping for it I'm thinking. lol
Arguing on the internet is like running in the Special Olympics...Even if you win...You're still retarded...
prints:http://vissroid.deviantart.com/store/
vissroid is offline
Old 04-22-2008, 07:16 AM   #103 (permalink)
what should be normally? like 10?
Old 04-22-2008, 07:57 AM   #104 (permalink)
Resident Ph.D Flaunter
aszazeroth's Avatar
Realname: Stefan
Send a message via ICQ to aszazeroth Send a message via AIM to aszazeroth Send a message via MSN to aszazeroth Send a message via Yahoo to aszazeroth Send a message via Skype™ to aszazeroth
Originally Posted by vissroid View Post
Actually I was tempted to contact you ...
You can drop me a PM in these forums if you like... I read them on the average once a day.
@edwardgtxy
Vissroid is quite right about the bump. I might elaborate some more in the tutorial appendix or in a more article style letter about the nature of maps and how they might interact. -IF- you go for a photoreal look, I suggest not having a bump at all, for a full disc render is the way to go. You have to go pretty darn close to a planet to actually resolve bump-i-ness. Even on smaller bodies like our moon, you need a pretty heafty magnification to detect "bump", although a smaller body have more elevation to radii ratio.
You might want to take a look at your atmosphere settings and the specular on land/ocean, but keep them renders churning out.
//Dr. Asz
________________________________
"The impossible only takes longer time"
[DrD] [WBD]
aszazeroth is offline
Old 05-22-2008, 10:41 PM   #105 (permalink)
Realname: Jeff
Such good work here, I'm still new to all this myself. I've started with a few tutorials and had some okay results in trying to make a mesh of earth (i needed it for an animation project, another learning experiance heh) My problem is atmospheres. I'd like to try to get the correct glow, without having to do it in photoshop as all this is gonna go into a scene. If anyone knows of any tutorials, or maybe some settings I just don't know about I'd be appreciated to any insight anyone can offer.
Thanks.
Treyvan is offline
Old 05-23-2008, 06:27 PM   #106 (permalink)
Realname: Colin Paddock
I don't mind the bump mapping. It's a little more than realistic, but not visually unpleasant. It looks like the water level is a little higher than the edge of the land. There looks like a vast wall of water around the low coasts.
Lower the water level, maybe reduce the bump amplitude a bit and it should be good.
If your going for fullan hard realism, remember that in scale the Earth is about as rough as a cue-ball.
su_liam is offline
Old 05-27-2008, 01:24 AM   #107 (permalink)
Realname: nate
Your surface is chopy and not properly spherlized, your shadow is overcontrasted and your glow is messed up. Make the inner glow a more realistic color and larger and fix the outer glow. I got some photoshop tutorials on this site if you need some help. That is, if you did it in photoshop.
sggrafixs is offline
Old 05-29-2008, 02:35 PM   #108 (permalink)
Demon Wing Commander
Chris Vickers's Avatar
Realname: Christopher S. Vickers
Send a message via AIM to Chris Vickers Send a message via MSN to Chris Vickers Send a message via Yahoo to Chris Vickers
Sir, would it be possible to get a pdf or Word Document of the information? Trying to put together a manual on a DVD for private use ONLY. I have no intent to redistribute it.
Support the New Galactic Network!
BoomStick! Productions Access Forum
Chris Vickers is offline
Old 05-29-2008, 03:16 PM   #109 (permalink)
aszazeroth's Avatar
Realname: Stefan
The PDF is the intended final format of the tutorial... I just have to finish off the last pages and add some cool stuff to an appendix. Time is my enemy here since I do all this on my spare time. But things are chilling down at work before the summer, so I might find time to finish it off soon.
//Aszazeroth
[DrD] [WBD]
Old 06-03-2008, 12:00 AM   #110 (permalink)
Lonewriter's Avatar
Send a message via MSN to Lonewriter
what happen to the pics on the front page? I am starting over on my planet and need to know the size to make my alpha map.
He's a high-tech redneck, Mayberry meets Star Trek.
He's a bumpkin' but he's plugged in, he's a high-tech redneck. -George Jones
Death and Limbo
Icon 3
Lonewriter is offline
