Old 02-05-2007, 02:53 PM   #71 (permalink)
Resident Ph.D Flaunter
aszazeroth's Avatar
Realname: Stefan
Send a message via ICQ to aszazeroth Send a message via AIM to aszazeroth Send a message via MSN to aszazeroth Send a message via Yahoo to aszazeroth Send a message via Skype™ to aszazeroth
Back to the planets for a while, trying to device a quick-n-dirty way of doing city lights. How about this ?! If you all like it I will add this technique to the tutorial. And... it's very quick, without masking out earth maps =)
Cheers
//Dr. Asz
________________________________
"The impossible only takes longer time"
[DrD] [WBD]
aszazeroth is offline
Old 02-06-2007, 10:47 PM   #72 (permalink)
aszazeroth's Avatar
Realname: Stefan
Alright... uploaded a more final version in the 3D gallery. Anyways. Here is a run down how I did the city map. First I went online and grabbed me a "real" street map from a driving-direction map site. One can use maps.google.com for instance. After a quick posterize in Photoshop I ended up with a nice 4 color map. Select the colors one like to be city roads. Discard the rest, perhaps paint some funky patterns and then blur it slightly. Convert it into a black white "alpha" map. Do a cloud + some inverted cloud renders on a new layer. Blend the new layer into alpha for variation/noise. There, now you have a white, noisy city map that you can slap into the self-illumination slot of your shader later on.
Quick-n-dirty... should not take long time and experiments to get something nice looking.
Cheers
//Dr. Asz
[DrD] [WBD]
Old 02-06-2007, 10:54 PM   #73 (permalink)
The Dwarf
Tinukedaya's Avatar
Outstanding Member! Sensei Challenge Honorable Mention
Total Awards: 2 (more» ...)
Realname: Karel
That really sounds like fast way to do that. Will check it once I'm finished with my current thing and when I return to the planet cretion tests.
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Corollary - "Any technology distinguishable from magic is insufficiently advanced." - Prof. Barry Gehm
current WIP: SFS War Hammer <- Stdby due to Viky
Tinukedaya is offline
Old 02-21-2007, 11:37 AM   #74 (permalink)
aszazeroth's Avatar
Realname: Stefan
Another quickie, and I tried to green-ify my tutorial map some in order to cheat me a nice and lush planet. Screen-capping some of the bump map generation stuff, so I will get back to the tutorial and finish of the land/ocean map creation with some words about specular and such... then we go skyhigh and to the clouds.
Cheers
//Dr. Asz
[DrD] [WBD]
Old 02-21-2007, 10:31 PM   #75 (permalink)
Ozylot's Avatar
2nd Place Award - Sensei Challenge 5 Sensei Challenge Honorable Member Award
Realname: Carl
Now thats cool!
- Ozy - A proud supporter of 3DScifi.com and SciFiers Anonymous
Current WIP: My site (Notepad :D )
Old Stuff: Gallery pics and wips...(Wings3D, Kerkythea & Bryce)
Ozylot is offline
Old 02-22-2007, 09:35 AM   #76 (permalink)
The Dwarf
Tinukedaya's Avatar
Realname: Karel
Originally Posted by Ozylot View Post
Now thats cool!
Uhm... What he said..
Old 02-22-2007, 11:44 AM   #77 (permalink)
aszazeroth's Avatar
Realname: Stefan
Alright... back to the bump map. In order to create a aussie (south coast) like shore effect I dropped a inner glow on the alpha channel selection. Quick notes are that I changed the default warm yellow to white, the "technique" to precise and I choose a different "contour". None really fitted the shore-slope so I made my own with the curve-editor.
Figure #something. The layer options dialog... learn how to use the force.
Figure #something+1. There are a few contours and you can make your own.
Right... now we have a default coastal slope. Time to paint some more bumps. The quick and dirty route... Grey scale your nice color map. Try trace edges on a duplicated layer, slap a nice blend on it (overlay maybe), then grab yer tablet pen and start tweaking around. I use soft brushes to start and then some brushes with fibers to the end. Apply with low pressure <= 10% and rather build up detail, than try to rely on a brush-patter "cloning" if you are not a master of such. If you paint outside... do not fear.. you can always clip that away with the ever so useful alpha channel.
Figure #something+2. Example of bumped island. Note that most of it are in the same-ish grey tones, as I wanted no real mountains and more of a flat landscape, sort of like Helgoland island for this corroded planet.
Alrighty folks... start bumping away. I think after this tutorial I'll show how I cheated and altered this planet to a lush green world, added mountains and rivers/lakes. But n ext on the meny are them .... daemons ... not quite... but clouds !
Cheers
//Dr Asz
[DrD] [WBD]
Old 02-25-2007, 04:44 PM   #78 (permalink)
aszazeroth's Avatar
Realname: Stefan
How's this for a tutorial PDF template ?!
[DrD] [WBD]
Old 03-27-2007, 08:56 PM   #79 (permalink)
Moderator With Rocks In
Martocticvs's Avatar
Moderator
Send a message via MSN to Martocticvs
I think it works pretty well. Are you planning on continuing this? This was definitely one I was watching quite closely.
Military-Meshes Admin | prdobson.com
Current Project: Cheyenne-class Starship | (Klingon Bird of Prey - on hold) | (Deep Space Nine - on hold)
DIMIDIVM·FACTI·QVI·COEPIT·HABET
Martocticvs is offline
Old 04-26-2007, 07:48 PM   #80 (permalink)
aszazeroth's Avatar
Realname: Stefan
Dammit... I should have posted something here some while ago... Well ladies and gentlemen. For the next part, go here Real Time Cloud Map and grab yourself a bunch of cloud maps. If that source is not enough try get some water vapor (usually in IR and no color information = good for later). There are a few NASA satellites (if my buddies have not got re-assigned to moon base yet) and some French and ESA ones, Meteosat comes to my mind. Watch out for artificially induced coastal / continental white borders. The geophysics guys tend to like those borders. They can of course be removed with the price of time and effort and preferably a tablet with a a pentagram in-graved and a lamb sacrificed.
After this we will paint some clouds using them maps as templates and clone-bases. In larger projects I start with painting a cloud-alpha to have for cutting away things just like the surface color alpha. It's neat and handy but not a must.
Now I will paint my map and I shall post it and some progress pictures as soon as possible =)
Keep up the good works folks
Dr. Asz, over and out
[DrD] [WBD]
