Poll: Did you find this tutorial useful?
Poll Options
Old 06-15-2006, 12:46 AM   #121 (permalink)
Veteran Member
scifieric's Avatar
Realname: Eric Reinholt
Originally Posted by dan1701a
I built an Enterprise in C4D using the Illustrator path for the primary hull as my starting point. Can trueSpace not import paths?
eg180 got it right in his listing, there was no such native device in TrueSpace 3.2 however you were able to purchase a plugin for this, although it never seemed to work correctly for me. I guess the structure would be perfect if you could, eh?
scifieric is offline
Old 06-15-2006, 12:49 AM   #122 (permalink)
Veteran Member
scifieric's Avatar
Originally Posted by malach
Okay, i'm working in tS 3.2
is there a way I can "lock" the background image in place so I can move stuff around and not have to re-line it up to my image?
Well, if you load the image into your background as in the first part of my tutorial, the image will never move. You are then free to move objects around to your liking ... but I don't recommend it.
This is going to sound stupid but if you move things too far away from the center, it's a pain to align them later and we're going to have to align them all to put them together.
I recommend leaving your objects centered (where your infinite lights, primitives or camera appear) and use the World View tools to move the background until they match up with the objects. Your final object will be centered and easily found when loaded into any other scene.
Old 06-15-2006, 12:52 AM   #123 (permalink)
Veteran Member
scifieric's Avatar
Originally Posted by evil_genius_180
Eric wanted me to post this, so I spent all last night going through the steps again myself and making pictures.
And a nice job you did, too. Thanks eg180!
Old 06-15-2006, 12:56 AM   #124 (permalink)
evil_genius_180's Avatar
No problem. Now about that sensor dome tutorial you promised...
evil_genius_180 is offline
Old 06-15-2006, 02:53 AM   #125 (permalink)
Veteran Member
scifieric's Avatar
Lower Sensor Dome
Okay, you've waited patiently ... you've asked politely and you've cornered me in dark alleyways with switchblades. So, okay, here's the Next Installment The Lower Sensor Dome!
Here are my best reference images that I've gathered from around the Net over the years. A lot of them are from Mike Trice's spectacular site.
Here is a close up drawing Alan Sinclair once posted on a site. (At least, I remember it as being Alan's ... hurm ...) It's a place to start but I think it's got a couple of details wrong. We'll go over that. First take a look.
I always wanted a detailed look at that area but if you create this set of features, the result looks a little bland and lacking in detail. This is augmented by the following image:
You'll notice there is an extra "lip" in this image. This is a shot from (obviously) pcmodeler.com. Going from the bottom up, there is a dimple, then the sensor dome which has a lip. That is all one glass piece, secured to the rest by two screws (I think). I'll try to find the shot that shows this but I can't remember where I put it.
Then there's almost the equivalent to two inner rings and an outer ring. The outer ring is "studded" by three rounded cones or dowels.
To more accurately reflect what you see here, I have amended Alan's excellent drawing. My two tiny additions are in red.
I think I should have reduced the size of the dowels but it's a start.
Old 06-15-2006, 03:05 AM   #126 (permalink)
Veteran Member
scifieric's Avatar
The Lower Sensor Dome Part II
I set this image as the background for trueSpace, first making certain that it would not change ratio. Then I outlined a spline for a template using the same techniques as in the first section of the tutorial.
Spline Path Tool
Remember to set the sharp corners with the spline attribute tool.
Adjust each of the spline point handles until you have corrected the automatic lengths and the result is smoother.
Old 06-15-2006, 03:16 AM   #127 (permalink)
Veteran Member
scifieric's Avatar
Lower Sensor Dome Part III
This normally unseen lip is what I think of as most important. It is not sharp. It has a fairly smooth transition into the lower lip.
Once you have the shape you want, right mouse click on the Lathe option. I have set this to be almost as dense as the saucer itself as I want it to hold up to fairly close renders.
Since I started my spline on the top left hand side of the drawing, my lathe automatically wanted to go off in the wrong direction. I had to flip it 180 degrees in rotation. The number of segments is 80 and change the default 270 degrees to 360. Finish the lathe with a left click on the lathe tool.
Left click on the object selection tool to convert your spline cage into an object.
I had extra polys on the resulting objectand deleted the extra faces by slightly overlapping them with a large box and then performing a boolean subtraction to remove the box and faces.
The result looks pretty good.
Old 06-15-2006, 03:32 AM   #128 (permalink)
Veteran Member
scifieric's Avatar
Lower Sensor Dome Part IV
You can sometimes remove extra polys by performing an object intersection. I loaded a large cube over my new spline-built object, making certain that the sensor apperatus was completely encompassed by the cube.
Pick your Object Intersection tool.
Glue the cube and you should reduce the polys around the flat faces of your object. Remember if it doesn't work, you can always try the subtraction method I mentioned before.
Next, I added a globe. I did not use the deformation tool, merely the object scale tool.
Once I had the globe the correct shape to fit the outline, I added a cube that was larger than the globe. I moved the cube above the intersection between the globe and the sensor platform and subtracted the cube from the globe leaving only what we need. Next, add a smaller globe and position it in place. Check in all three planes to make certain of alignment and perform an object union with the larger globe.
Old 06-15-2006, 04:04 AM   #129 (permalink)
Veteran Member
scifieric's Avatar
Lower Sensor Dome Part V
We are missing the lip of the globe itself. For this I used a simple primitive place, scaled to match the thickness of the lip and joined it with a simple regular round polygon.
After making an object union and subtracting the excess round polygon with another plane, I positioned the template and right mouse clicked the lathe tool.
I matched the number of segments of the sensor assembly and lathed. I used the object union tool to join this to the globe.
We should now have two halves: Assembly and Globe.
"But, but Eric" you say. "You have made your sensor assembly shorter than the actual object! What gives?"
A good question!
Real world objects are rarely sharp. The real model has filler smoothing the transition between the sensor assembly and the lower hull. I want to duplicate that a little.
I used a new perspective view and rotated the view around to the top of the sensor platform.
Next I chose Point Edit: Faces and selected the top of the platform.
Next, right mouse click the Sweep tool to bring up it's options. I reduced the sweep to it's lowest size 0.001 and left clicked the sweep tool.
On the point nav tools that opened up with with the Point Edit: Faces tool, select the Point Scale option. Make sure your grid mode is set to off. You can widen the selected face very slightly.
Old 06-15-2006, 04:23 AM   #130 (permalink)
Veteran Member
scifieric's Avatar
Next I added a low poly cylinder of about 40 faces and a sphere set to the same number of faces (20 over 40). Boolean Join the two objects and re-size them to fit the dowels in the illustration. Position the first of the dowels on the edge of the assembly and make sure it matches the position on the plans.
Next, select your object rotate tool, turn on the grid mode and right mouse click the grid mode. This will bring up the object rotate options (the angles that you will move an object with the grid mode on). I'm going to rotate our dowel in the front view new perspective window so I changed the Z axis to 120 degrees and turned off all other axis. If you have any doubts about which plane you are using, just change all of them to 120 degrees.
Why 120 degrees? There are three dowels so take 360 and divide by 3! This isn't strictly accurate but it will match our plans.
Next, make sure your dowel is selected and then pick the Axis tools. Select the Normalize Location option which will move the axis of the dowel to the very center of the work area. So long as our Sensor platform is also centered, this will work perfectly.
Select the Move Up in Hierarchy tool (big gray arrow pointing up next to the object rotate icon) and the dowel will highlight again.
Duplicate the dowel and select your object rotate icon. Right mouse click in the front view new perspective window and pull down or push up until your copy of the dowel moves 1/3 of the way around the assembly. Duplicate this and repeat. You should now have three dowels.
Done! Glue all the objects together and save.
Import into your saucer scene, reposition and save.
Is it perfect? No, but it looks close and should serve our purposes. I think our ersatz copy compares nicely to the original.
