| Newly Added Models This forum is for the announcement of newly uploaded models to scifi-meshes.com. You MUST be registered to download files. |
| Beeeeeeeep! Join Date: Jan 2008
| New File Added: Colonial Fleet low-poly (3ds) Downloads: A new file has been added by Aceman: Colonial Fleet low-poly (3ds) Model Format(s): 3DS Version: 1b Textures Included: YES Polygons: NA Credit Requirements: Battlestar Galactica models (based on new TV series) by Coxxon Description: Hope you enjoyed the first version and thanks for downloading this revision. Lots of changes and a couple of NEW ships. New stuff - NEW ship: My own design - Colonial Ares Bomber: newer than the MKII Viper but older than the MkVII Viper, it is a two crew ship with external cannons, undermounted side missle launchers and a multi-compartment internal bomb/missle bay. - NEW: Hi-poly-low-poly Galactica - The Battlestar Galactica with full ribbing. It is in 4 sections each offset by 600m (units). You will probably need to reset the texture usage on the "small" (some first and mainly second texture) and "rib" sections (all third texture). - NEW: Added modified Raptor- "Combat Raptor" with additional weapons as seen in the third season. - NEW: Added Cylon Centurion - not to scale, but a pretty good low poly character (yes, I know the back isn't correctly modeled, but I like it that way )Individual ship change list: -colargo1cox - No change (NC) -colastr1cox - Reworked disk thickness and underside disk forward detail "greeble." Some texture fixing. -colbmb1cox - New ship see above -colbstr0cox - New higher poly Galactica. See above. Uses 3 textures - colbsg1cox, colbsg2cox, colbsg3cox -colbstr1cox - Multiple texture changes -colbstr2cox - Reworked nose, neck, ribbing, and texture of Pegasus -colcels1cox - Reworked underbelly tube, and bridge plate -colcld91cox - Reworked texture, added dome flight pontoons -colclm1cox - NC -colcol1cox - NC -coldefn1cox - NC -colflat1cox - NC -colgem1cox - Some texture modification -colgem2cox - NC -colline1cox - NC -colmftr1cox - Reworked wing, guns, nose, hull insets, undercarriage, texture -colmftr2cox - NC -colminr1cox - NC -colmvr1cox - NC -colpyln1cox - NC -colRailGunLowcox - NC -colRap1cox - Reworked antenna, uvw coord, texture -colRap2cox - "Combat Raptor" - added missle launchers, rockets, bombs, and side guns -colRefn1cox - NC -colrstr1cox - Slight texture change -colshtl1cox - NC -coltube1cox - NC -cylbstr1cox - Added a new texture that reflects a closer version of the Season 3 Basestar -cylftrh1cox - Minor texture changes -cylmftr1cox - NC Have fun with'em & give credit for model and texture use. |
