| Notices |
| Physical Modelling Sometimes it's nice to be able to pick up and hold the results of all your hard work. Be it a kit, scratch built or Rapid Prototyping, post your physical modelling results here! |
| | #72 (permalink) |
| SFM Oracle Realname: Jedman67 Join Date: Jul 2006 Location: New York
Downloads: 0 Uploads: 0 | |
| "But when the Starship Titanic finally launched, it did not even manage to complete its very first radio message — an SOS — before undergoing a sudden and spontaneously-massive total existence failure." -Douglas Adams, Life the Universe, and Everything | |
| | #73 (permalink) |
| Resident Time Lord Realname: M. Shaw Join Date: May 2006 Location: Scotland Age: 24
Downloads: 0 Uploads: 0 | Soz for asking, but whats the Diff between the Reg Ent-D model from the show and the 'Generations' version? it is basically the same, but smaller and better detailed in the hull etc? |
| | #75 (permalink) |
| SFM Guru | fantastic job! |
| "It is useless to resist!" - Darth Vader [WIP] Corellian Corvette | [WIP] X-Wing | [WIP] Lambda Shuttle | [FINISHED] TIE Fighter | |
| | #78 (permalink) |
| Would you kindly? | Is the lower and upper saucer being done as one piece? If so, how do you plan to light it? Is this simply a master for creating a mold? Have you worked on the upper saucer at all? Why is the area where the cobrahead fits filled in? Why is the sky blue? Where do goldfish go when they die? Is Schrodinger's cat alive? Um... Awesome work. Keep on posting. |
| ˙ʎɐʍ ƃuoɹʍ ǝɥʇ pǝddılɟ slɐɯɹou ʎɯ ʇǝƃ ı uǝɥʍ ʇı ǝʇɐɥ ı | |
| | #79 (permalink) | |
| Senior Member Join Date: May 2006
Downloads: 0 Uploads: 0 | Quote:
This is a master that will be molded, then clear fiberglass castings can be built up. The upper and lower will be made seperate. The reason the impulse engines and neck cutout are filled in is for ease of molding, they'll be cut out later on the casting. | |
| | #80 (permalink) |
| SFM Obsessed Realname: Brian Join Date: May 2006 Location: Denmark Age: 34
Downloads: 0 Uploads: 0 | ^ Ah sorta like working in Sub-D... some stuff you wait with till after you've collapsed the mesh, and then cut it... makes for a cleaner mesh, and subsequently for cleaner cuts! Excellent work man |
| When they build you brother... they broke the mold - Bruce Springsteen. | |
