| Physical Modelling Sometimes it's nice to be able to pick up and hold the results of all your hard work. Be it a kit, scratch built or Rapid Prototyping, post your physical modelling results here! |
| SFM Nugget Realname: rolly Join Date: Jun 2006 Age: 26
Downloads: 2 Uploads: 0 | so i haven't been working on this model because i was not motivated enough. lately i have been wanting to start a new model and that made me pause and think for a moment. so i decided to actually put some effort and finally finish this model. here's a few updates upto where i have stopped before: i manage to paint it gray ![]() ![]() ![]() after painting it there were a lot of scratches and bumps in the model and it is not the smooth finish i was looking for, so i ended up sanding and reputtying it untill i got most of the subtle lines from sanding it with a lower grit sand paper. here are the most recent update: the model itself is now fully assembled and ready to be painted. the model itself weights over 3lbs (it looks like i didn't use enough foam) so i ended up using a plumbing tube to support the model. back view ![]() looking on ![]() oblique view ![]() side view ![]() looking oblique from back ![]() looking head on ![]() right now i am looking for a nice stand i can display the model with. the model requires another major sanding and final reputtying and sanding. hopefully i can finish her up in the next two weeks. painting would be quite tricky and i am not using any decals.... which is still an option for me but i still have to design it. i am thinking of painting it by hand using the dots (stipulate) method from starshipmodeler website. anyways i will leave it to that for now. cheers rolly |
