Go Back   Scifi-Meshes.com > Member Artwork Gallery > Physical Modelling
Physical Modelling Sometimes it's nice to be able to pick up and hold the results of all your hard work. Be it a kit, scratch built or Rapid Prototyping, post your physical modelling results here!
Old 08-01-2008, 06:28 AM   #1 (permalink)
Realname: Chris
10k scale Allegiance SD/SSD master WIP
here is some sketched of how i was thinking of making the major parts of the ship
OdysseySlipways/Allegiance SD-SSD - Photobucket - Video and Image Hosting
here i begin making the lower hull. it is made from .040 ABS sheeting from Plastruct. i thought that if i made the sides of the sheet of plastic the center line of the hull, it would match up easier. in the first shot you'll see where i cut out for the 2 small hangars. nothing else shown here other than the cross braces being added in
OdysseySlipways/Allegiance SD-SSD/5-31-08 - Photobucket - Video and Image Hosting
not sure what i was doing here
OdysseySlipways/Allegiance SD-SSD/6-1-08 - Photobucket - Video and Image Hosting
not sure what was done here other than i took note on how tall the hull was, not to my liking
I may have added the stripping for the brim trench lips
OdysseySlipways/Allegiance SD-SSD/6-2-08 - Photobucket - Video and Image Hosting
I'm not sure if this is where i had changed out the cross braces on the top and bottom hulls, giving the hull's cross section a lower profile. i know it was here or the day before
here i started adding some of the larger raised armor plating to the lower hull. i wasn't sure how i was going to make a straight line from one side to the other, so i started by cutting the plastic with one squared ends, these ends would meet in the center of the hull and then be laid down, i would then mark the edge of the hull onto the plastic so i would know where to make my cuts. it worked out pretty good.
to help keep the gap between the one set of armor plates, i just decided to use a strip of plastic. i figured why not, if the first piece was glued in place and it looked pretty good, why not just follow it...... so i did
OdysseySlipways/Allegiance SD-SSD/6-8-08 - Photobucket - Video and Image Hosting
here is started the upper hull. rather than cutting out two pieces like i did with the lower hull, i cut them out together as one piece and then scored down the center where i started to bend it. but before i could bend the hull, i drew out on the computer the size of the opening i wanted for the tiers, printed it out, and then cut through the paper into the plastic. it worked rather well. you will also see that i added cross braces to the upper hull as i did with the lower hull. you can also see 2 pictures of both hull halves next to each other showing the outside and insides
OdysseySlipways/Allegiance SD-SSD/6-15-08 - Photobucket - Video and Image Hosting
in these pictures i started adding .040 thick strips to make a lip for the Tiers to sit on. I also started the first Tier, but stopped when i got to trying to get the right pitch for the roof. the way i was trying to work out the pitch was by taking .250 wide strips of plastic and using that as a guide by putting it on it's side, on the hull, but when the two strips met in the middle, i kept being just over 1 mm between them in their height. For the life of me, i don't know what the problem is, so i tired again.......... and again............. and again........... and then called it a day
OdysseySlipways/Allegiance SD-SSD/7-10-08 - Photobucket - Video and Image Hosting
after trying to figure out why i couldn't get one side to match the other at the center point, i finally gave in and just split the difference. from this point, everything seemed to flow nicely. I started the first Tier level
OdysseySlipways/Allegiance SD-SSD/7-23-08 - Photobucket - Video and Image Hosting
here you will see that last Tier levels being added. each Tier level is separate from the other. there are 4 pieces so far to the Tiers. the spine will be a separate part as well
OdysseySlipways/Allegiance SD-SSD/7-24-08 - Photobucket - Video and Image Hosting
Odyssey Slipways is offline
Old 09-02-2008, 05:43 AM   #2 (permalink)
Realname: Chris
okay, been a little while since i posted here any updates, so i'll post them by their dates......
8-28-08
in this picutre i did a little sketching of what i'd like it to look like
1basiclayout.jpg - Image - Photobucket - Video and Image Hosting
in this picture i have laid down the first layer of .020 x .100 and then began adding on some other shaped pieces of .020
2.jpg - Image - Photobucket - Video and Image Hosting
in this one i added just a few pieces of .010 strips and chips
3.jpg - Image - Photobucket - Video and Image Hosting
in this shot you may make out a few more pieces of .010 added
4.jpg - Image - Photobucket - Video and Image Hosting
i thought if i turned the hull around the other way, the flash may throw a bit of a shadow to see things a bit easier, but it doesn't seem to be the case 5.jpg - Image - Photobucket - Video and Image Hosting
as you can see in this pictures, i tried to add a little bit of perspective to it, but it didn't come out too clearly
6.jpg - Image - Photobucket - Video and Image Hosting
this one also shows a little bit of persective to it, but this time i didn't use a flash so you can se a little bit more
7.jpg - Image - Photobucket - Video and Image Hosting
all of this is giving me some idea as to how i'll be having the Brimt trench done for the Ertl 1:4222 scale SD kit when i get to it (hoping before the end of the year).
I still plan on adding smaller little wedges of plastic do give it more detail along with another level of .020 and then detail out some of that level, then i just have 5 more sides to do like it.
hope you like the brim trench so far (now that you can see it )
8-29-08
well, i did some more detailing of the first level, just adding a few more shaped chips to fil it out some more.
not sure why but the front half of the trench just doesn't seem to be the same as the back - or is it just me?
if i manage to get anything else done on it tomorrow, it will hopefully be adding the second level of .020 and then dtailing that as much as possible.
i know yesterdays pictures were hard to see what detailing was added, but i think you'll like these pictures even more
OdysseySlipways/Allegiance SD-SSD/8-29-08 - Photobucket - Video and Image Hosting
9-1-08
not too much new to show. I did start the next layer bbut not quite as i was planning. I was hoping to add another .020 and add some more detailing, but i found i was only able to add a .010. the only way i might have been able to add the .020 was if i were to push it down hard in the back, but when i did this, i think the lavels would start to tilt and make it all unlevel (going arcross the hull from side to side).
i did start adding the fist level (.020) to the other side.
OdysseySlipways/Allegiance SD-SSD/8-31-08 - Photobucket - Video and Image Hosting
Old 09-02-2008, 08:32 AM   #3 (permalink)
Battlefleet Admiral
Kadaeux's Avatar
Realname: Kitt
Ouch, thats a really painful format you're using there matey, the work looks very good but having to click on a link just to see the picture is an extreme pain in the ass. Just post the pictures in the thread using the links like everyone else.
Reality is like a kick in the balls, you see something you like and WHAM.
FIRESTORM My Greeble Project
Warhammer 40'000 team., | Warhammer 40'000 Threads thread.
My planet Tutorial
Kadaeux is offline
Old 09-03-2008, 04:37 AM   #4 (permalink)
Realname: Chris
because some still use dial up (as i am again) and if i where to post all of the pictures in this thread, the page would take for ever to load up.
Old 09-03-2008, 05:32 PM   #5 (permalink)
chrono's Avatar
Sensei Challenge Honorable Member Award
Which is why the Attachment & Thumbnail features exists.
Sig's too long... NanoGator
chrono is offline
Old 09-04-2008, 05:24 AM   #6 (permalink)
Realname: Chris
not sure how to do that i doub't it's clicking onto the insert image as i have just tried that a few times and nothing....... could be cause i'm on dial up, donno
Old 09-06-2008, 05:53 AM   #7 (permalink)
Realname: Chris
here are a few pictures, others can be seen via the links posted above postings
this is the right, rear Brim Trench
this is the front, right Brim Trench
this is the left, rear Brim Trench
The basic Tier levels tack-glued in place until surface detail is added
This is the upper hull sitting next to a casting of the Avenger SD and the new Escort Carrier
Old 09-06-2008, 05:57 AM   #8 (permalink)
Realname: Chris
here are two more picutres. i won't post any more in this thread until i get something major done to it
Reactor Bulb and raised armor plates
3 raised armor plates
