Go Back   Scifi-Meshes.com > General Discussions > General Discussion > Science Fiction Writers forum
Science Fiction Writers forum This are is for those of you who like to write scifi or create a history or backstory as part or your design process
Comment
Article Tools Display Modes
<!-- google_ad_section_start -->Cargo shuttle flight cockpit transcript - Something a little different<!-- google_ad_section_end -->
none
Published by sorceress21
03-30-2007
Just for kicks I decided to write a fictional transcript of cockpit and radio communications for a trip from Atlanta International Aerospaceport to a space station in medium earth orbit in a civilian Goliath SC-60 owned by FedEx. This is modeled after real world IFR flying and may be a preview of things to come.
To keep things less cluttered I'm not going to write in radio calls between controllers and other aircraft or shuttles that would be heard by our flight crew.
Player acronyms:
PIC – pilot in command
SIC – second in command
CGM – cargo master
CDL – clearance delivery
GC – ground controller
TWC – tower controller
ATC – air traffic controller
OTC – orbital traffic controller
SVC – station vicinity controller
It opens on the north general cargo ramp with the preflight done and before engine start checklist complete
Intercom-
CGM – Okay gentlemen, cargo door secured, CGM go for flight.
SIC – Roger that, secure for departure.
Comm 1
SIC – Atlanta clearance, FedExstar two one six, Sagan station.
CDL – FedExstar two one six you are cleared to the Sagan orbital transfer facility via radar vectors PALGE, then the CADIT four departure, RESPE transition. Climb and maintain three thousand five hundred, expect flight level three three zero for boost to orbit one zero minutes after departure. Departure frequency one two five point seven. Squawk eight two one two six.
SIC – FedExstar two one six is cleared to the Sagan station, vectors PALGE, CADIT four then the RESPE transition, climb maintain three thousand five hundred, expect flight level three three zero for BTO in ten minutes, departure frequency twenty five oh seven and eighty two one twenty six on the squawk.
CDL – Fedexstar two one six read back correct. Contact Atlanta ground on one twenty one point niner for engine start and taxi clearance.
SIC – two one six roger.
Intercom –
PIC – Alright we ready to go?
SIC – Yes sir let's do it.
PIC – Okay call em up.
Comm 1 –
SIC – Atlanta ground, FedExstar two one six on the north cargo ramp ready for start with Bravo.
GC – FedExstar two one six stand bye.
Two minutes pass
GC – FedExstar two one six cleared for engine start. Gimme a call when you're ready to go.
SIC – Two one six go for start and we'll call ya on the ready.
Intercom –
PIC – Taxi Engine start checklist please.
SIC – Fuel boost one through four on
PIC – Boost pumps alive and the pressure's comin up.
SIC – Separators one thru four on.
PIC – Sep's on
SIC – Core containment system's one thru four enable
PIC – CCS's online and in the green
SIC – Core auto controllers enable
PIC – Enabled
SIC – Left ground area clear
PIC – Clear left
SIC – Number one autostart engage
PIC – Number one alive, pressure's alive, plasma temp stable…..Number one engine nominal, idle power
SIC – Number two autostart engage
PIC – Number two alive, pressure's alive, plasma temp stable…..Number two engine nominal, idle power
SIC – Primary power source select set to generator one
PIC – P P S to genny one
SIC – Stand by power source select set to generator two
PIC - S P S to genny two
SIC – Voltage check
PIC – Voltage good
SIC – Amp check
PIC – In the green
SIC – APU one mode select to stand bye
PIC – APU one to stand bye
SIC – Engine instrument check one and two
PIC – In the green
SIC – Taxi engine start checklist complete
PIC – Taxi checklist now please
SIC – Alright, beacon on
PIC – check
SIC – Nav lights on
PIC – Check
SIC – Taxi lights on
PIC – Check
SIC – Nose wheel steering lock disable
PIC – Disabled
SIC – Flaps thrity
PIC – Comin down
SIC – Slats twenty
PIC – Slats comin down
SIC – Brake pneumatics test
PIC – Test good
SIC – Cabin pressurization test
PIC – Test good.
SIC – Flight instruments set and check
PIC - Check
PIC – Alright let em know we're ready to go.
Comm 1
SIC – Atlanta ground FedExstar two one six ready to taxi.
GC – FedExstar two one six, roger. Taxi to runway two six right via taxiway alpha seven, left turn on taxiway alpha hold short of alpha six.
SIC – Two one six taxi to two six right alpha seven, alpha, hold short of alpha 6
PIC releases brakes, adds power on number one and number two engine for taxi. Taxi's as instructed.
GC – FedExstar two one six give way to the Airbus A590 on taxiway alpha six crossing from your right, then cross alpha six, taxi to and hold short of runway two six right, call tower on one one nine point one when ready.
SIC – Okay, two one six, cleared to cross alpha six after the Airbus, hold short of two six right.
Airbus passes
Intercom -
PIC – Clear right?
SIC – Clear right.
PIC taxi's as instructed to assigned runway stops behind three other aircraft holding for two six right. SIC switches to comm 2
Comm 2-
SIC – Atlanta tower FedExstar two one six ready to go for two six right in sequence.
To be continued....
Published by
sorceress21's Avatar
All Sketched Up!!!
Send a message via Yahoo to sorceress21
Article Tools
  #1 (permalink)
By hal on 03-30-2007, 02:21 PM
Tower voice: Flight 2-0-9'er cleared for vector 324.
Roger Murdock: We have clearance, Clarence.
Captain Oveur: Roger, Roger. What's our vector, Victor?
Tower voice: Tower's radio clearance, over!
Captain Oveur: That's Clarence Oveur. Over.
Intresting idea, don't know where your going to go next with it, i'll be watching for the next part! over!
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Article Tools
Article powered by GARS 2.1.6 ©2005-2006
