Go Back   Scifi-Meshes.com > General Discussions > SFM Support Forum
Notices
SFM Support Forum Post problems, suggestions, and site related questions here.
Old 12-01-2006, 04:24 AM   #61 (permalink)
C0D3 FREAK!
Norman's Avatar
Admin
Realname: David Bates
Send a message via ICQ to Norman Send a message via AIM to Norman Send a message via MSN to Norman Send a message via Yahoo to Norman
Actually for the rotating banners.. we have it so i t refreshes on each page load.. however we can institute a "caching" system where it will change every x number of seconds.. but then we get into a little more complicated code.. but it's very possible
I can use an eternal number style of file and use that.. *thinks*.. or I could.... *walks off mumbling.. *
*returns mumbling*
EDIT:
And for those of you who know CSS, I will be redoing the header part so it will use one image, will be faster more streamlined and all I have to do is throw in a couple of classes and a div *returns to hole*
Norman is offline
Old 12-01-2006, 09:00 AM   #62 (permalink)
biotech's Avatar
Realname: Rich
That star wars one looks a bit amaturish compared to the others.
biotech is offline
Old 12-01-2006, 09:17 AM   #63 (permalink)
MadKoiFish's Avatar
The dashed lines are a bit odd and the frameless boarder makes it seem theres something not loading. Lines dash in the page area tops and oddly dont dash between some posts in the new post results. (dashes only above posts with the smileys in them)
I like the on relaod header change, I hope its kept that way.
MadKoiFish is offline
Old 12-01-2006, 01:24 PM   #64 (permalink)
Administrator
Aceman's Avatar
Admin
Realname: Chris
Uploads: 7
Send a message via ICQ to Aceman Send a message via AIM to Aceman Send a message via MSN to Aceman
MadKoiFish - I hadn't looked in that area. Thanks for the heads up I'll see about getting that fixed. (dashes only above icon'd posts).
I'll also test a framed version, even if it's just a very dark line to edge the threads/posts
Aceman is online now
Old 12-02-2006, 02:05 PM   #65 (permalink)
Talos's Avatar
Realname: Sean Little
Send a message via AIM to Talos Send a message via MSN to Talos
I'm not sure if anyone else is having this problem, but I keep getting the old scheme back, as well as new posts from a couple days back. A refresh fixes it, but it comes back every once in a while.
I took this screenshot when it happened about five minutes ago.
EDIT: Btw, when it does that, it says that it's 1536 on Nov 30.
Talos is offline
Old 12-02-2006, 02:43 PM   #66 (permalink)
MadKoiFish's Avatar
Delete everything in your temp net dirs its prolly caching from a cookie someplace.
Old 12-03-2006, 03:05 PM   #67 (permalink)
Senior Member
DAve's Avatar
I'm loving the new header & logo!
DAve
DAve is offline
Old 12-03-2006, 03:32 PM   #68 (permalink)
scotty73's Avatar
Realname: Scotty
As a new member "ish" all i can say is I think the site is great. I have had no problems navigating around it, and would say its very user friendly. The only suggestion would be to make sure the members artwork/modeling/forums are kept as the main priority, as without them there would be no site. As I said its great and keep up the great work.
thanks for a cool site.
scotty73 is offline
Old 12-03-2006, 06:04 PM   #69 (permalink)
Talos's Avatar
Thanks Koi, that worked like a charm.
Talos is offline
HTML code is On
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
