| SFM Support Forum Post problems, suggestions, and site related questions here. |
| | #15 (permalink) |
| Administrator | This is actually defined in the templates. If you are using templates other than the SMF08 ones, you will not get the excluded forums from the new posts link at the main menu bar. It's possible that Ace forgot to change this in a couple of spots in the templates, and so depending on the link you are using, as Novak pointed out, you will get the News forums as well. I am at work right now and can't check on this with more depth, but a quick way to solve this would be to only use the new posts button in the navbar for the SMF08 templates. All the older templates do not have the exclusions though, so if you are using those, you are screwed either way, heheh. Melak's tip will work though....if you bookmark that link, it'll remove the mentioned forum ids from the new posts section. |
| Personal website (New version up - now web developer oriented) "Chuck Norris destroyed the periodic table, because Chuck Norris only recognizes the element of surprise." Current WIP: Defiant Class - Finished | |
| | #16 (permalink) |
| Administrator | BTW, if you are using the New Posts link in the SFM08 templates without being logged in, you'll also get all the news, so make sure you are logged in before clicking on it. |
| | #17 (permalink) | |
| SFM Guru Realname: Alexander Join Date: May 2007 Location: Same place as your keys and the remote Age: 19
Can we turn her off? or are we stuck with her like an unwanted Vegas Marriage? | |
| ||Offline||Amazonia Class||Decepticon: Soundwave||U.S.S Tyche (Old) ||Works In Progress||Tyche Class: Revamp ||Complete:|| | ||
