Page 5 of 11 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 105
Thread: The Never Ending Project.
  1. #41
    SFM Obsessed XFozzboute's Avatar
    Join Date
    May 06
    Location
    face down in my own vomit, I think it's mine anyway.
    Age
    48
    UPDATE...
    And I declare this table done.
    You can visit my blog at http://xfozzboute.wordpress.com/
    Children are the Zombie Apocalypse. But without the fun parts.
  2. #42
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    I’ve been just to busy with personal matters to get any work done but things are starting to calm down, for now. Started to work on a dresser that I’m gonna keep. It’s a real pain in the ass with all the goofy shapes and I had to go back and forth on this thing to get it right. And my computer might be dieing because even after cleaning the fans a bit it still is kind of slow.
  3. #43
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    Decided to work on the bedroom more so I can get an idea of what I want to do with it. Iíve already pulled up the old carpet and started to put primer on the walls.
    Anyway. Hereís more work done on the dresser. I probably wonít work on this more untill I lock down what I want to do with the room.
    Iíve found the color of the walls. Itís called Robin Hood Green. I also changed the trim around the floor. Iím also gonna install laminate flooring. I thought about hardwood but laminate is cheaper and looks just as good. Only problem is Iím not sure what direction it should go in. The floor texture is temp for now.
    Here is another look with the floor in another direction and I added the second table. My bed will go between the two tables. Iíve already picked out the bed that I would like to have but I wonít get it till the room is finished.
  4. #44
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    Back to the dresser. The top is just about done. The shapes on this thing is killing me. There is no way I could the complicated handles on this thing so I did up a set of nice simple ones.
  5. #45
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    As far as I’m concerned the drawer is done. I tried ambiant occlusion again and took at shot at adding chromatic aberation. I’m kinda happy with it even though I didn’t really know what I was doing.
    And because Rigel over at Foundation 3d asked for a reference picture here it is.
  6. #46
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    I think I’m pretty much done with the top of the dresser. I just need to take a look at a few places that the measurments might have been wrong.
  7. #47
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    Ok getting started on the bottom of the dresser. Thankfully I don’t need to do much additional building. Just reuse the parts I’ve already made. The heat over the last few days have been killling me.
  8. #48
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    Well as far as I’m concerned the dresser is done. I’m very proud of how it turned out.
  9. #49
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    The bedroom door is just about done. I’ve added rosettes and a door handle that needs to be finished. I still need to finish up the closet and the windows. After I finish up this room I may end up rebuilding the stuff I’ve done for the basement.
  10. #50
    Join Date
    May 06
    Location
    Age
    48
    UPDATE...
    I found a temp bed and lamp online so I can get a better look of how the room will look. Positions and textures are also temp. Trust me, I don’t have a white bed with pink covers.
    The closet is just about done but I need to work on the light and add access to the attic.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
