uploading your renders would help
there's not much to offer here, rendering with motion blur and sufficient aa should be all that's needed for good stars
using a sphere and an emitter won't make any difference, the environment map can sometimes be better but that's because the stars are lower resolution and therefore blurry, which is basically the same as your big blobby stars
the only other thing I can suggest is to export motion vectors and apply the motion blur to the stars in post, I do it a lot with pretty good results
Bookmarks
