Page 13 of 13 FirstFirst ... 3910111213
Results 121 to 127 of 127
Thread: Incom Corporation's T-65 X-Wing Fighter
  1. #121
    SFM Nugget jrhottel's Avatar
    Join Date
    Nov 12
    Location
    N. CA, S. Arizona
    Wow I really like this! Can you elaborate on how you're using Inventor in your pipeline? What Advantages do you derive from using Inventor and how do you envision using it going forward? Thanks
    U.S.S Pintado SSN-672 1988-1991. USAF C-5 Flight Engineer Retired, 2008. In both services supported operations of DSRV's Mystic and Avalon.
  2. #122
    SFM Obsessed Schimpfy's Avatar
    Join Date
    Jan 07
    Location
    Ohio
    Age
    39
    Amazing work. I love the detail you're putting into this. I can understand your passion for aircraft and how they work. I'm the same way although I'm just a weapons loader, but I'm a detail freak and love to see work like this.
    I had a similar setup for landing gear on a Trek ship that's been an ongoing project. I think I like yours better.
    "No man fears to kneel before the God he trusts. Without faith, without belief in something, what are we?"
    1:16, 2:4, 3:23, 5:8, 6:23, 10:9, 10:13 - The Roman Road
    MOLON LABE
  3. #123
    SFM Nugget Hyqs's Avatar
    Join Date
    Feb 13
    Location
    NYC
    Quote Originally Posted by jrhottel View Post
    I use Inventor in conjunction with AutoCAD. I draft most things out in 2D using photos. From there I decide what parts to create and form an assemble. I then list the parts in a spreadsheet before I create them. In case youíre not familiar with Inventor, itís a prototyping program. It keeps each part in a separate ďpartĒ file. Parts are then loaded and ďassembled.Ē The assemble files can be loaded into other assemble files, building a hierarchy of the model. Each file holds the instructions for creating or assembling the object in its file. When one file is loaded into another, only the object information goes, not any instruction code. This object information can be optimized and reduced in size. In the end the model can be optimized and exported to 3dsmax. The only real drawback Iíve found is that you must make sure your size relationships are correct at the beginning. There is no way to globally resize an assemble. That is one of the reasons I draft everything out first. Iím sure other solid modelling programs work in a similar manner, but this is the only one Iíve used. If youíre looking to model realism and detail I recommend it. On the other hand, modeling extreme detail is a time consuming endeavor. This project turned out to be a sort of engineering, reverse engineering thing.
    P.S. I have images of most of the assembles on my site.
    http://www.incomcorp.net/development.html
    Synclair Hyqs
    Engineering Department Head
    Incom Corporation
  4. #124
    Join Date
    Nov 12
    Location
    N. CA, S. Arizona
    I mean to give Inventor a try, more with and eye to product prototyping, 3d printing and maybe even homemade CNC. With Respect 3d-modeling though I'm curious if it adds much to modeling time and what advantages you find in using it instead of say modeling only in Max.
  5. #125
    SFM Obsessed Saquist's Avatar
    Join Date
    Apr 10
    Location
    Houston TX
    Inventor is intuitive. It uses the designn tree method to allow you to change your design even after you finished. The model is convertible to Max.
    I work with it every day but havnt gone into this kind of detail with lofting.
    Opening of Star Trek Secion 31
    " You believe your world is safe? It is an illusion, a comforting lie told to protect you. We deal with threats to the Federation. Threats that jeopardize its very survival. If you knew how many lives we've saved... you'd agree... the ends justify the means." ~Galo Saldivia
  6. #126
    Join Date
    Feb 13
    Location
    NYC
    Back to working on the R2 unit.
Name:	C-S00-R_Shoulder - Right.png
    Synclair Hyqs
    Incom Corporation
  7. #127
    Join Date
    Feb 13
    Location
    NYC
    Been real busy. Haven't had time to model in awhile.
    Synclair Hyqs
    Incom Corporation
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
