Page 57 of 82 FirstFirst ... 74753545556575859606167 ... LastLast
Results 561 to 570 of 819
  1. #561
    Join Date
    May 06
    Large rooms on the corners with those stepped cutouts I mentioned. It might mess with those green windows but I think I have enough clearances to all the parts to retain them as rooms.
    -= BLOG| WIP BLOG=-
  2. #562
    Join Date
    May 06
    Filled in the shield grids on the forward as I disliked the look and set up the dark plating on the forward hull and then today it got it's unique windows and rooms. These might be a bit excessive in size but I can adjust them later on.
    -= BLOG| WIP BLOG=-
  3. #563
    Join Date
    May 06
    Grids redone and looking at putting length markers on the strips. Might pull those off as doing such on other strips might be too much of a headache.
    -= BLOG| WIP BLOG=-
  4. #564
    Join Date
    May 06
    Some update stuffs.
    Some of the lower hull stuff is just rough ideas or messing about while I decide what to do.
    -= BLOG| WIP BLOG=-
  5. #565
    Join Date
    May 06
    Getting a bit cartoony as all the panels are just cut faces with the dark carpet teal on. They will be the same as the ones on the upper saucer in the end so much less prominent. Maybe it is too busy?
    -= BLOG| WIP BLOG=-
  6. #566
    SFM Obsessed Rekkert's Avatar
    Join Date
    Dec 08
    Location
    Buenos Aires, Argentina
    Age
    25
    I don't think it's too much, no. However I find the black areas between the escape pods and the registry a bit weird, the pincer shape doesn't flow with the rest of the design in my opinion.
    If you're interested in commissions, please visit this page
  7. #567
    Join Date
    May 06
    yup I changed those out before quitting last night. . . I had hoped a inverted angle opposite would work out but that central stuff just broke the idea. (seen from the side that curve was a negative angle to the hull.)
    One render showing panel alterations from last night and others are grids and one of those rooms that just duplicates to the other side. Ignore the white sipe things as they are not what I plan to do not to mention the color.
    -= BLOG| WIP BLOG=-
  8. #568
    Join Date
    May 06
    Wonder if I am getting lazy. After all the odd things I did with the IOWA thing's windows and special rooms I feel I have sort of cheaped out on this ships cutout rooms and whatnot.
    examples:
    -= BLOG| WIP BLOG=-
  9. #569
    Join Date
    May 06
    Ok planning out all these annoying not numerically dividable panels! These domed panels will be hopefully detailed out like the upper hull ones in roughly the same position on the top saucer. AND of course ignore all the pinch errors as max is again turning those edges the wrong way.
    -= BLOG| WIP BLOG=-
  10. #570
    Join Date
    May 06
    prolly spent too much time on the imported model than I should have.
    not that original in the end. . . . . dunno what do for torps with out the roll bar thing.
    -= BLOG| WIP BLOG=-
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
