Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: TOS U.S.S. Enterprise Filming Sets
  1. #11
    SFM Guru BlobVanDam's Avatar
    Join Date
    Mar 12
    Location
    Sydney, Australia
    Age
    33
    Awesome detailing!
  2. #12
    SFM Guru Tralfaz's Avatar
    Join Date
    Dec 09
    Location
    London, ON, Canada
    Quick update. Been working on creating animated GIF textures for use on the computer monitors. This is a first test. The separate GIF textures are all timed differently between the frames, but for some reason, they seem to kind of sync up when used in C4D.
    https://youtu.be/AWzJH2CyIO0
    I hope when I die, my wife doesn't sell my toys for what I told her I paid for them.
  3. #13
    SFM Guru trekki's Avatar
    Join Date
    May 06
    Location
    Germany
    Hi Al,
    very beautiful. Can you use GIF animations in C4D as texture?
    greetings
    Trekki
  4. #14
    Join Date
    Mar 12
    Location
    Sydney, Australia
    Age
    33
    Quote Originally Posted by Tralfaz View Post
    I don't use C4D, but is it possible it doesn't recognize variable frame times and just plays them all back at a fixed speed? Perhaps try exporting them as videos at a fixed frame rate like 15/30 fps possibly in a format like .mov (with png compression or something) if it supports it.
    It's going to look so cool with all of those animated boards in there!
  5. #15
    Join Date
    Dec 09
    Location
    London, ON, Canada
    Thanks Trekki. Yes, C4D can use animated GIF images for textures. That is how I was able to get the computer displays to work. There are 4 separate GIF's being used here.
    Thanks BlobVanDam. I believe when I created the animated GIF, I told the software that it was to be 24 frames per second. The timing between each frame was in 1/100ths of a second and I guess it averaged the time the best it could. In C4D, you can have the animation sync to each frame or second. I chose frame as it was more granular. At least I think that is how it works. So, at 24fps, each frame would cover .0417 seconds. And if this is true, then I can kind of see how things would appear to sync up.
  6. #16
    SFM Guru SeanP's Avatar
    Join Date
    May 06
    Location
    Edmonton, Alberta, Canada
    Age
    49
    Looks great, can't wait to see it finished.
    Building Models In 3D Studio MAX Since 1996 And Still Learning!
    All New - Check out Book #1 in the Tactical Advantage Series - Alien Genocide at seanpatrickposey.com
  7. #17
    SFM Guru seanr's Avatar
    Join Date
    May 06
    Location
    Brooklyn, NY
    Age
    40
    All the images are broken (3rd party hosting temporarily disabled) - looks like you've hit some kind of download limit?
    Sean Robertson | webolutionary@webolutionary.com
    ~member of the Insane Detail Club
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
