Page 22 of 27 FirstFirst ... 12181920212223242526 ... LastLast
Results 211 to 220 of 261
Thread: Beyond A
  1. #211
    Join Date
    Mar 07
    Age
    26
    nightfever, thanks! I sent you a PM with this conversion. Again, absolutely stunning model, I'm in love with it. Especially impulse engines, to make them cast light properly, I had to add 128 lights, one for each little part of engines
    My youtube channel.
  2. #212
    Join Date
    Jun 06
    Age
    32
    Quote Originally Posted by evil_genius_180 View Post
    According to Bernd Schneider, it's 150% larger than the Enterprise's saucer. Remember, in the shot I posted, the Enterprise is considerably closer to the camera, because it's flying directly at that saucer but has enough time and space to maneuver under it.
    And, in 1080p, you can make out part of the name "Mayflower" and part of the registry number. The USS Mayflower is one of the ships in the fleet that went to Vulcan.
    Schneider isn't a reliable authority on these things anymore. He's committed to his own interpretation of the data. He doesn't seem to take lens effects and camera angles into consideration.
  3. #213
    Quote Originally Posted by gerb200 View Post
    Bernd uses massive confirmation bias to come to his scale conclusions. He interprets the evidence in such a way that all things that confirm his desire for the ship to be small are included in the analysis and all that contradict his desire are excluded.
    Whether the ship started at a smaller size and was later scaled up, it was at least scaled up in such a way that the design still works and still makes sense. So what if the windows are bigger? They're still of a perfectly plausible size. Instead of a 1m tall window you have a 1.5m tall one. They way it has been scaled means the number of decks is simply doubled. So you have two rows of windows on the saucer rim. It is a mistake to assume the saucer rim has two decks however. There could be a deck between the rows of windows afterall and at the ship's bigger scale it fits in there perfectly. The designers and modellers clearly responded to the director's request to enlarge the ship with enough care that all the ship's details still make sense.
    The bridge window would simply not work if the ship were 300m long. Bernd never even mentions this.
  4. #214
    SFM Guru trekki's Avatar
    Join Date
    May 06
    Location
    Germany
    Enterprais
    Hello, can you see a few pictures?
    Where do you place the lights?
  5. #215
    Join Date
    May 06
    Location
    Ohio
    Age
    39
    OK, not arguing the point. I could be wrong. I watched the Vulcan arrival sequence last night on YouTube and it looks in the distance shot that the saucers are the same size. Since I can't fathom why they would change size between shots, it could just be a perspective issue.
  6. #216
    Join Date
    Feb 10
    Location
    Quebec, Canada
    Age
    53
    I think the saucer would be larger because of the bowling alley. Clearly it's not there in the first 3 films, so you would need to enlarge the saucer for that...And I am not even speaking of the SPA yet, which would seemed an essential in space.
  7. #217
    Join Date
    Mar 07
    Age
    26
    trekki, well, almost everywhere they should be, here are some screenshots.
ID:	114634   Click image for larger version.
ID:	114635   Click image for larger version.
ID:	114636   Click image for larger version.
ID:	114637   Click image for larger version.
    My youtube channel.
  8. #218
    SFM Obsessed oldmangreg's Avatar
    Join Date
    May 10
    Location
    What? You rapist!
    Age
    28
    Could of just done an emissive material for the impulse using either the Glow mental ray material or Architectural material.
    https://renegadeinitiative.wordpress.com/
    "It's about the future, Madame Chancellor. Some people think the future means the end of history. Well, we haven't run out of history quite yet. Your father called the future - "the undiscovered country". People can be very frightened of change."
  9. #219
    Join Date
    Feb 10
    Location
    Quebec, Canada
    Age
    53
    Quote Originally Posted by oldmangreg View Post
    I was asking myself the same question...never seen so much Omni lights on a model. Usually I use them for warning lights. Otherwise I switch to mental Ray render and put Glow material for windows, energy strips and such...make it simpler to handle them over a bunch of lighting objects. That depends on what renderer you want. I know MentalRay can be limiting in terms of importing the model...I often debate the value of mentalRay because of the exlcusion/inclusion of the Glow texture. Kind of a Love/hate relationship.
    You can download VoyagerNutrek as example of mentalray texture here. look at the nacelle energy strips (also windows, deflector energy, etc...):
    http://www.3ddub.net/public-files/
    You also have tutorials about mentalrays and glow in youtube. Hopes it would help. Be aware that mentalray would change your global lighting sheme. Usually it,s better to have 2-3 global Omni lights.
  10. #220
    Join Date
    Mar 07
    Age
    26
    Believe me guys, I know what are you talking about, that's the first thing I tried and it just doesn't work. The illumination of self-illum materials is really limited in mental ray and the worst part - I can't set attentuation boundaries which means - mental ray FG process the whole scene for every self illuminated material and it will increase the render time quite a lot.
    Finally finished those two artworks..
    ..Oops, the images didn't attach..
    My youtube channel.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
