Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 92
Thread: Spaceship "Electra" by I14R10
  1. #1
    SFM Nugget I14R10's Avatar
    Join Date
    Feb 14
    Age
    27
    Hi Everyone
    This is spaceship "Electra" (maybe? the name is also WIP) designed by me. For some time I wanted to design entire spaceship and this is the result. I have a short story behind this spaceship, but it's only bunch of ideas that need to be put together in a more complete story.
    This is basic story.
    420 years from today, fractures in space time are discovered in Alfa Centaury system. Later that same year they are discovered in Epsilon Eridani star system too. 1 year later they are discovered in Earth system. Normal matter can't fall into the fracture because of repulsive force from the fracture. But they have some other effect that is discovered later and it's a big danger to our universe. This ship is sent to investigate the fractures and see if they can be closed.
    That's all folks for now! Let's go to the art.
    I'm working in blender. Cycles renderer is used for rendering images.
    I had about 20 different ideas for the spaceship and I liked this one the most of all.
    I currently have basic structure and looks of 5 rooms in the spaceship. And I have two types of corridors. This is the first one
    This is the second one. This one needs more work
    I have 5 rooms that are early in the design phase. Engineering is one of them, but it's a bit more developed than the others
    It's not a lot, but it's something. I should make more visible progress when I am done placing the corridors. There's not point in showing concept art that is not even half developed.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    SFM Pimp Army evil_genius_180's Avatar
    Join Date
    May 06
    Location
    Ohio
    Age
    39
    I like the exterior of the ship. However, the corridors look a lot like the ones in the Enterprise-D on Star Trek: The Next Generation.
  3. #3
    Join Date
    Feb 14
    Age
    27
    Quote Originally Posted by evil_genius_180 View Post
    Is that good or bad? But honestly, I don't see much resemblance although I do draw inspiration from Star Trek design.
    I'll think about designing another more different corridor.
  4. #4
    Join Date
    May 06
    Location
    Ohio
    Age
    39
    I didn't say it was exactly the same, but it is similar. Let's use some better screen shots, for one thing. I headed over to TrekCore and grabbed some HD screen shots from The Game, a season five episode that I knew had at least one chase through the corridors.
    Your corridor ideas have a similar layout and overall look. You have lights along the base boards and ceiling in similar patterns. You even have the shiny black panels. (LCARs displays on Star Trek) Your color pallet is similar. At the very least, it looks like the inside of a Starfleet facility or ship.
    Whether or not that's a good thing is up to you. If you want it to look similar to Star Trek, then you're fine. You certainly wouldn't be the first person to draw inspiration from Star Trek in their own non-Trek universe stuff. However, if you want your stuff to stand on its own, then it's a bad thing.
  5. #5
    Join Date
    Feb 14
    Age
    27
    Well, for sure I like Star Trek and I like the colors from TNG sets. I didn't notice that they are alike, but now I do when you pointed it out. But I'm not sure if what I want. I will continue working on this and see how other interiors turn out.
  6. #6
    Join Date
    Feb 14
    Age
    27
    I took your advice and tried to get away from Star Trek-ish look. This is a bit darker, more 2001 Space Odyssey- look. I kept the colors the same, I like them, but I think that this time it doesn't look that much like star trek. Ignore the wooden buklheads, they will change. They are wooden for now.
  7. #7
    Join Date
    May 06
    Location
    Ohio
    Age
    39
    Very nice. It definitely doesn't look Trek anymore.
  8. #8
    Join Date
    Feb 14
    Age
    27
    Thanks. That's why I like to post on these kind of forums early during modeling. You can get good feedback about your work. I like the new corridor better than old ones now.
  9. #9
    SFM Guru psCargile's Avatar
    Join Date
    Sep 07
    Location
    Warner Robins, GA
    Age
    49
    The wood is a nice aeststic, though, and there is always a possibility of biology mimicking composite materials that have a wood look, but are more stronger than steel.
    The ship design is nice too.
    Keep moving forward.
  10. #10
    Join Date
    Feb 14
    Age
    27
    yes, I thought about that. Maybe I'll do it that way.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
