Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Re: ST:TMP Drydock (WIP)
  1. #1
    Join Date
    May 09
    Location
    Illinois
    Click image for larger version.
ID:	114034Although I've been working on this model for about 3 years now, It's still a WIP. I'm getting closer to it's completion now. This Drydock is scaled to the Deboers 1/260 scale Enterprise model and is one of 2 docks that I will be building.For now I'm* in the November update for 2016 and I should have a new update in a couple of weeks. Enjoy.
    November Updates - 2016
    For this month's update I've finished wiring all of the turrets with their lighting effects. I've fed the wires through the bottom section of the turret and through a styrene tube at the back of the base of the turret. This makes it look more the filming miniature versions. After getting this all set up and adding the fiber optic strands to each of the work booms*I've also been working on the painting of the Work booms as well as the booms for the Work Light Array. There are 3-4 different colors used on these pieces. The main color was and off Yellow which somewhat resembles the color of our modern day work cranes. There are also gray and rust color stripes added as well as some military green. They were sprayed in layers, masked and then the next color was added. The final color was the yellow. They will need some touch ups to cover up some small pot holes created by the resin-molding process.
    On the 1/350 scale dock I was not sure how I would mount these turrets to the dock because at that time there were no good pictures of the dock available. What you saw on the screen was all I could go by. But having seen the filming miniature in person I now know what to do to mount these pieces to the 1/260 scale dock.
    There are some specialized mounting brackets that hold the turrets into place, so I'm trying to replicate them as best as I can using styrene. So far they are turning out okay and they look like they'll be able to support the weight of the turrets, especially the light arrays.*I should have them all painted up by the next updates. There are 20 new pics under the November Updates - 2016 page. Enjoy and feel free to comment. Thanks everyone. See you next update!
    Mark
  2. #2
    Administrator Comco's Avatar
    Join Date
    May 06
    Location
    ACT, Australia
    Hi NemVia - did you have an image you intended to attach?
  3. #3
    Join Date
    May 09
    Location
    Illinois
    oops!. Sorry about that.... For some reason this sight is not allowing my pics to be uploaded at the moment. I will try to figure out whats going on. For pics visit my website:
    Mark
  4. #4
    Join Date
    May 09
    Location
    Illinois
ID:	114032Click image for larger version.
ID:	114033February Updates - 2017
    SO WHAT HAPPENED TO DECEMBER AND JANUARY????????
    Uh..... I dunno..... Just had to take a break. Been*busy with work family and a multitude of other things...... BUUUUUUUUUT! I'm ready to get moving again.
    The pics are loaded up on the February Updates - 2017 Page.
    *Okay, so I really didn't get a whole lot done the last couple of months, But I did manage to work on a few things. The mounting clamps for all of the work booms are now complete and I mad the pincers for the ends of the booms. I kind of improvised on these because I couldn't see any functional need to the Drydocks end pieces as seen in the movie. I will be making alternate pieces that mimic TMP end pieces so they will be interchangeable. They will just slip onto the ends of the booms. Anyway, the booms were cut to the same length when I first made them and I really can't finish them until I get the Enterprise in place. Then the booms will be cut to the appropriate lengths and the end pieces will be put on. I will also cut the optic fiber to be flush with the end of the boom.
    Back to the turret clamps. I have these mounted on the bottoms of the swivel shaft and they are painted up to match the panel frames.* I've also started to do some re-wiring on the Enterprise Deflector dish. my client wanted the ramp-up, ramp-down*lighting effects added in so I need to run a few more wires through the dorsal. I've also replaced the LED in the dish reflector with a dual color LED. I should have this wired up by next update.
    In other areas, I'm starting to apply the decals for all of the shuttles that will go in the Aft Hanger bay. I also needed to take out some of the wiring for the thrusters on the Enterprise model to make room for the Gang way on the Dock. There's just too much packed into it and it might cause problems later on. I've also mounted the Enterprise onto the dock but I'm afraid the ship might just weight too much for the bracket, so I might have to stabilize the ship with some wires. .013mm I think is*what I bought.
    I know this wasn't much of an update, but I should be back on track during this month. Thank you everyone for your patience. I know this is a long project, but please bear with me and you WILL see it complete. Ahh yes I love that word complete. So check out the pics, let me know what you think and I will see you next month. Take care everyone.
    Mark.
    ...once it's activated, there's no way to stop it - Scotty DMa
    www.NemVia.net
  5. #5
    Join Date
    May 09
    Location
    Illinois
    New weblink:
    http://www.nemvia.net disregard anything with previous website. I'll explain later.
    Mark
    www.NemVia.net
  6. #6
    It's Grim up North! Samurai's Avatar
    Join Date
    May 06
    Location
    Texas, USA
    I removed the links to the prior website for you- just keeping things family-friendly.
    “ALL THESE WORLDS ARE YOURS, EXCEPT EUROPA.
    ATTEMPT NO LANDING THERE.
    USE THEM TOGETHER. USE THEM IN PEACE.”
  7. #7
    Join Date
    May 09
    Location
    Illinois
    Thanks Samurai. My feelings exactly. I've been wasting time getting to the bottom of all this. Thanks for your help!
    July Updates - 2017
    Hey Everyone! My apologies to all for the big delay. As you may have noticed my website was hacked and my NemVia.com version of my is no longer functioning for my website. I have had to update my site to NemVia.net and try to clean up as much of the garbage that the hackers have caused and try to get things back in order as best as I could. I've had a few setbacks with the Drydock build, sick relatives and other problems have caused further delays. Although I do have a small update for this month I think you'll find some of it interesting.
    I became discouraged when I found out that I made a mis-calculation with my armature for the ship. This armature was to keep the ship level inside the dock and also allow it to appear to be floating while inside the dock. I poured over ways to correct this problem including some extremely thin steel fishing line that would hold the engines level with the dock.* I decided to do what I did with my 1/350 scale dock armature and just bend the heck out of the thing until it help the ship upright and level the way I wanted it to.
    Using a pair of pipe wrenches, I found the point where the armature meets the connection rod and pushing in opposite directions I twisted the armature enough to pre-load the tension in order to hold the weight of the ship in place. I have a pic of how I was able to do this in the July Updates - 2017 page. It took me a couple of tries, but I finally got the ship to appear level inside the dock. She FLOATS! I exclaimed! Anyway that was a huge hurtle to get past. Now I can finish the wiring for the main deflector dish and torpedo launchers and finally seal off the saucer section and get ready to add the port side panel frames into* place.
    In other areas I had to replace the hanger deck on the aft side of the Dock. Some of the fiber optics were not lining up the way I wanted to so I redid the entire deck. It looks much better now and I have all of the chase lighting done for the entire aft end of the modules. The small hangers have the chase lighting heading into the deck whereas the larger hanger has the lighting running in take-off mode with a few shuttles in position for launch. I have 7 new pics and 4 new videos of the chase lighting effects in this month's updates I should be able to get more done in the upcoming month. Once again I apologize for the long delays. Hang in there and I'll get this thing done soon. Thanks for your patience and keep checking for more updates.
    Mark
    http://www.NemVia.net
    www.NemVia.net
  8. #8
    Join Date
    Jul 06
    Age
    34
    I think it looks great
    I wonder if it is possible for you to photograph it like they did in 1979. This would mean taking multiple images and combining them I think? Composite the various layers and then tweak them in photoshop or something until it looks 'movie like'
  9. #9
    Join Date
    May 09
    Location
    Illinois
    July Updates - 2017 - Supplemental...
    Okay, I usually don't jump ahead of my posts here, but I just had to add this to the blog.... I recently purchased a 80cm motorized camera dolly and I wanted to use it for several special photography effects on the side. But most importantly, when I finished the drydock build I wanted to make a duplicate flyby movie that would match ST:TMP's drydock flyby. I made a few passes with the model in it's unfinished state to get an idea of what I can do for a final project for this build. The results of the tests came out very good even though the lighting was not corrected the models are incomplete, none of the effects lighting is operating and there is no space background. But if you could just ignore all of that and take a look at the video's potential, you might understand why I had to do an early posting of this video. Now I really can't wait to finish this project. Take a look at the test video. *https://youtu.be/n4EtoOLRdgg
    See you in a few weeks
    Mark
    www.NemVia.net
  10. #10
    Join Date
    May 09
    Location
    Illinois
    August Updates - 2017
    This has been an eventful month. Adding the Test video of the Enterprise flyby to my library has given me a little extra motivation. I want to thank all of you who have checked out the video on youtube.* I am looking forward to making my own ST:TMP version of the flyby when I'm finished, shot for shot. Also I'm planning on making an additional version that would include portions of the Enterprise and Drydock* that were not shown in TMP. Any ideas? Let me know.
    In this month's update I've been concentrating on getting all of the wiring done for all of the hanger bays on both the front and aft sides of the dock. I finally was able to hook up all of the chase lighting on all of the hangers as well as their overhead lighting. I wanted to have the overhead lighting on the hangers rather than the rear walls glowing to make the modules appear more like a gigantic space warehouse for supplying and/or repairing any starship that might pull into this humungous dock for repair/refit/resupply.* This is also why I wanted everyone to see inside at least one of the hangers. If I didn't need the support framework on the inside of the modules to hold the model up, I would have made the hanger even deeper into the model. But space was limited. But, I've permanently added the shuttles into the hanger deck and at least four of them are lit. I will be adding crewmembers as well as work bees and cargo containers to add depth of scale to the dock. I also added some red LEDs to the front hanger as seen in TMP. I would guess that the RED lights would be a warning to small craft that it is not safe to enter the dock at this point. That is why on the open hanger on the aft side I'm using green LEDs to indicate it is safe for departure or arrival onto the hanger. The chase lighting on the open hanger is heading outward indicating clearance for launch.
    I've also added the top f the module to port side of the dock in one of the pictures. I wanted to make sure it seated the right way and would not interfere with any of the wiring and optical fibers. It fits very snug and can be removed to access the lighting and wiring.
    Getting back to the Enterprise, I am adding some super strong magnets to a few parts of the ship. Mainly the saucer and the main deflector dish housing. This will also allow access to some of the wiring. I will be finishing that wiring up as well as for the photon torpedo launchers. There are a few more small details I have to add to the ship and then do another wiring test before I seal everything up. I can then add the Enterprise permanently to the dock structure and wire it into place. After that I can begin adding the port side panel frame assembly. Keep checking for the updates. I can actually see an end coming for this build. FINALLY! Then I can look forward to making some nice HERO shots as well as the long awaited FLYBY Video. Exciting times!
    Well that's it for this update. Enjoy the pics in the August Updates 2017 page. Talk to you in a month or so.
    Mark
    www.NemVia.net
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
