Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Classic Version, Jupiter 2 from the BW Series.
  1. #1
    Welp...after finishing the Bridge for SATR...I am going to start another project that I am dying to start...its the Classic version Jupiter 2 from the Tv Series.
    It was hard to find the floor plans of the ship, but I did find some...hope you guys enjoy my work.
ID:	115622   Click image for larger version.
  2. #2
    SFM Guru Tralfaz's Avatar
    Join Date
    Dec 09
    Location
    London, ON, Canada
    Nice job on the modeling, but unfortunately, you aren't using blueprints for the classic Jupiter 2. They look like the re-imagined blueprints where everything fits properly inside the Jupiter 2.
    I hope when I die, my wife doesn't sell my toys for what I told her I paid for them.
  3. #3
    Quote Originally Posted by Tralfaz View Post
    I know, but these floor plans are much better...I wish I could find the original ones, but no luck..
  4. #4
    just some guy rojren's Avatar
    Join Date
    May 06
    Location
    Louisville, KY
    Age
    54
    Yeah, looks like Avian's revised plans for the web series. Didn't that got lawyered out of existence?
  5. #5
    Gave it some thought, and I really want this to be more accurate to the tv show, and so since I can't find any pics of the floor plan of the original Jupiter 2. I took some pics of my Model Kit of the ship...crude, but it works.
    I just have to fix it to scale though.
  6. #6
    Little Update...
ID:	115633   Click image for larger version.
  7. #7
    New update..
  8. #8
    SFM Guru Avian's Avatar
    Join Date
    Mar 10
    Location
    Minneapolis-St.Paul
    Yes, you were using my plans for the 98-foot Jupiter 2 I designed for the web series. That size is just about the minimum diameter you can make the J2 and have it fit both upper and lower decks in. There is a thread on this very site all about the creation of that model.
    If you want to use the 47-52 foot "original" size, you won't be able to do a lower deck. (Well...you could, but it would have to be squashed vertically). But you can still fit the entire upper deck as seen in the show inside that size of ship. Our friend here, "Tralfaz" also did an excellent version on this site!
    For my J2, I found a nearly complete set of plans re-drawn from the original Fox Studio blueprints by a guy whose online nickname is "Starseeker" over at HobbyTalk. I don't know if they are still online but it's a start. There are a ton of reference images from the show online as well. Another good source of knowledge and images is the Lost in Space Forum on Proboards.
    You can check out all the other J2 versions here by simply searching the threads. Some threads are old so it'll take you a few pages of listings to find them. Also take a look at my YouTube channel for more reference videos. (It's name is "Haselius00") And, if you have specific questions about dimensions, I can probably answer them!
    I very much encourage you to continue on with this project. It's fun to see other modelers and their interpretations of the ship!
  9. #9
    Quote Originally Posted by Avian View Post
    If you want to use the 47-52 foot "original" size, you won't be able to do a lower deck. (Well...you could, but it would have to be squashed vertically). But you can still fit the entire upper deck as seen in the show inside that size of the ship. Our friend here, "Tralfaz" also did an excellent version on this site!
    Thank you...it does mean a lot to hear from an advanced modeler. I am still learning, and thank you also for the other areas for reference. For now, I am just going by my Model I put together with a change to scale...But I will check out the other reference location's if needed....again thank you. You did an Awesome job on the drawing of the J2...truly amazing.
  10. #10
    Join Date
    Mar 10
    Location
    Minneapolis-St.Paul
    Thank You, meshmaster! I know a lot of fans from - ahem - another sci-fi show from that era look down on Lost in Space. And there are many good reasons to do so when it comes to storytelling. But, for my money, Lost in Space had the very best art design when it came to the Robot, Chariot Space Pod and Jupiter 2. Nothing in the other series came close to the detailing or expense lavished upon Lost in Space, which was the most expensive TV series of the era. And even when it comes to the ridiculous papier mache heads of LIS aliens, I'll calmly point to a Gorn.
    Just keep going with it. I learned soooo many modeling skills creating the Jupiter 2, and it was just damn fun!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
