Old 05-14-2008, 04:00 PM   #1 (permalink)
NewsHottie's Avatar
Protect any hard drive with the DataLocker Drive Enclosure
Maybe you're a spy or you've got schematics for the next hot gadget locked away on your hard drive, but either way you're going to want to lock your files down. That's where the DataLocker Drive Enclosure comes in. The DataLocker is an enclosure so you'll have to supply your own 2.5" SATA hard drive, which is the standard size drive for laptops. After that, you create a 6-digit passcode that you punch in on the unit's backlit touchscreen. Tap it again to lock that sensitive info down. It's powered and enabled by your USB port. Plug it in, put in your code and access your data.
Security doesn't come cheap, though. Get ready to drop $100 — you can find your average 2.5" enclosure for $10.
More...
NewsHottie is offline
