Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 78
Thread: A Sovereign styled Nova
  1. #11
    SFM Nugget WideFoot's Avatar
    Join Date
    Sep 14
    Location
    Hampton Roads. In SE Virginia? hit me up!
    The video card decided that everything should be green and that screens should only update every other second. It is a bit of a hindrance to modeling.
    I still have my work laptop, but it is a 5-year old Think Pad to which I am not allowed to install programs. Surfing the web is about as interesting as it gets.
  2. #12
    Join Date
    May 06
    Location
    Ohio
    Age
    39
    At least all you need to replace is the video card. It could be worse.
  3. #13
    Join Date
    Sep 14
    Location
    I get a friend's computer for a few days while he's away on business! So, I made some new nacelles.
    I was thoroughly unhappy with the ones that I had added as placeholders.
    In the continuance of mixing styles, I needed something which has shape cues from both the sovereign and nova classes. It turns out, they have surprisingly different nacelles.
    I'm debating whether I should round the edges on the bottom side. It would make things somewhat messy, but might add some attractiveness.
    Click image for larger version.
  4. #14
    Sensei Deks's Avatar
    Join Date
    May 06
    Location
    Scotland
    Age
    35
    The smoothness you have right now on the nacelles looks good to me.
    To be honest, while I did like the overall design of the Nova class, the fluidity was frequently broken with harder edges on the nacelles, while TNG tried emphasizing the 'smoothness' and fluidity of the Galaxy class all round for instance.
    The Intrepid compromises on fluidity with nacelle pylons for example and even sometimes seems a bit too 'busy' on the outside.
    Anyway... have you considered perhaps extending the aft portion of the nacelle pylons so they look like an arc where they connect to the nacelles going further backwards (similar to what I scrubbed up in MS Paint)?
    Hehe... I apologize if I ruined the look of the image, but I feel lazy and MS paint is a bit more limited than Adobe.
    But you get the idea.
    Environment shapes Human behavior. Greed, selfishness, competition, etc. are learned patterns of behavior as a result of living in an outdated socio-economic system that's based on scarcity and an unsustainable ideology of 'indefinite growth on a finite planet' that creates conditions where such behaviors will inevitably emerge.
    We need to unleash our science and technology into the social system which desperately needs an update.
    Reserarch the Venus Project and Resource Based Economy
  5. #15
    Join Date
    May 06
    Location
    Ohio
    Age
    39
    The nacelles look good. It's good that you were able to work on it some more.
  6. #16
    Join Date
    Sep 14
    Location
    Well, that was an excellent idea!
    By the way, if anyone knows how to retrieve dialog boxes (which don't appear on the taskbar or in the alt-tab selector) from screens which are no longer attached to the computer, I'd love a solution.
  7. #17
    Join Date
    Sep 14
    Location
    It's time to think about greebles and windows and such. I went into this without any particular deck spacing in mind, but by complete chance, an 11ft. floor-to-floor height works perfectly in this ship. (yes, I know, Trek ships are done in metric, but by training I'm an architectural engineer in America and was taught exclusively in the imperial system.)
    By comparison, a typical concrete office building has a f-t-f height of 10 ft. and a steel building has 12 to 14 ft.
    I was looking at the curves in the saucer and I am worried that the deck spacing and window locations will conspire to interrupt the bezier curve I have draped over the saucer which I was going to use for texturing.
    I plan on mounting a pair of impulse engines to the lower/aft edge of the saucer.
  8. #18
    Join Date
    Sep 14
    Location
    http://imgur.com/a/GqQXp
    By the way, all images are here. There are a few earlier images of the ship before the initial blocking was complete.
  9. #19
    Join Date
    May 06
    Location
    Scotland
    Age
    35
    Hm... I was wondering about greebles and things on ships.
    Namely, TOS Enterprise was originally imagined as most of the things being on the inside the ship... namely, technical efficiency means doing more with less.
    We could try to apply this analogy here for example.
    Some detailing on the hull can certainly be made, but avoid making it too busy... as if you want to emulate technical efficiency... things such as shield emitters and sensor arrays would probably be part of the hull - namely, designed to be part of the hull plating (think transparent windows that are capable of producing power from sunlight - that kind of thinking).
    I was thinking on integrating something like that onto the Nightfire as I think that too much detailing might be the wrong direction for an advanced space-faring culture that's a lot more advanced.
    But I digress, it's your design...
    Btw, the new nacelle pylons certainly do look more appealing...
  10. #20
    Join Date
    Sep 14
    Location
    ...Actually, I was planning on cutting all kinds of holes in this hull.
    Specifically:
    • Replicating many of the sensor arrays of the Nova Class
    • Adding hull plate details similar to the Sovereign Class
    • Adding a smattering of windows
    • Vents in the nacelle struts
    • Escape pods
    • Impulse engines
    • The hull plate grid detail (which many claim is the way deflector shields are projected)
    But, I am planning to make the unblemished base model (the condition it is in now) available along with the final model.
    I do understand liking the smoother style. In TOS, that was a holdover from the smooth V2 rocket styled ships of Buck Rodgers and other works of that era. But, after 2001: A Space Odyssey, I think we can find a nice balance between the overall shape of a thing and the minute details in it.
    And, Frankly, I like making the gritty stuff and looking at it.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
